#661
Old 03-29-2015, 07:25 AM
Bentwheelbob's Avatar
Bob, I run those same rockers in 1.5 ratio and couldnt use the tall or shorter Comp cams nuts, so I went with stock style brand new nuts and all worked well, with those Rockers, under factory chrome covers. Good luck!
Uh oh..I was worried that the comp poly locks would still leave me high and require using a short billet spacer. Could you please provide a link or part number for the stock style nuts and I'll just go ahead and order some. I really want to get this thing buttoned up this coming weekend.
These are 1.52 ratio rockers with PN 0245501.
Thanks Bruce.
  #662
Old 03-29-2015, 07:40 AM
68ragtop's Avatar
68ragtop 68ragtop is offline
Originally Posted by Bentwheelbob View Post
We need more cowbell...
here you go......
Engine looks great, did you decide if your going to spray hi temp paint on the exhaust ports yet?
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
  #663
Old 03-29-2015, 07:47 AM
I painted the exhaust ports on the head and the exhaust runner area on the top and bottom of the intake with brush on POR 15 exhaust manifold gray paint. I'll paint over these areas with engine paint and hopefully when it burns off the gray will remain and keep things rust free.
  #664
Old 03-29-2015, 07:51 AM
68ragtop's Avatar
Have any picts of that? I haven't tried it. The last couple i did I used ceramic silver header paint from rattle cans. Works really well. Any paint looks better than quick to rust steel when it burns off.
Plus its easier to touch up. what did you decide on engine color? Sorry if you posted that above, I'll peek again.
89 Trans am GTA
  #665
Old 03-29-2015, 08:05 AM
Here's pictures of the intake. heads and exhaust manifolds after POR 15.
  #666
Old 03-29-2015, 08:22 AM
68ragtop's Avatar
Oh, wow! that looks pretty much like cast as evident in your intake picture. No wonder I didn't see it.......
89 Trans am GTA
  #667
Old 03-29-2015, 04:56 PM
dreamn69 dreamn69 is offline
Bob,
You may try this guy for Yellow Hose. He list them for Corvette, surely they would be the same.
http://shop.docrebuild.com/1978Corve...placesGMt.aspx
1972 Formula 455HO
1979 W72 Fire Am
1975 455 4 speed TA
  #668
Old 03-29-2015, 06:31 PM
Yeah, I tried docrebuild. They were hateful and no help. They only sell Corvette headlight kits and don't sell by the foot. I did end up buying a vette headlight kit from another vendor because it looked like it had yellow in it. As it turns out it has a lot of yellow stripe, but it is like 7/16" OD. It also had lots of blue, red and white of the correct diameter that will be useful.
  #669
Old 03-29-2015, 07:20 PM
Alvin's Avatar
Alvin Alvin is offline
Bob: All kidding aside, I love this thread! Thxs for sharing all of your various trials, tribulations, successes and methods.
  #670
Formulabruce's Avatar
Bob, you running stock 3/8 Rocker stud? ( the stock are screw in 7/16 at base and 3/8 on top)?? IF so this is the link for the nuts youll need, IF you run the straight 7/16 Ill get you a different link, Bruce
THIs link is for 3/8 STUD at rocker arm.. and is for ONE Head only
http://www.summitracing.com/parts/sum-g6800-k/overview/
" Long may we DRIVE !"
  #671
Old 03-29-2015, 07:31 PM
Bruce,
Sorry to be a pain here, but I am over my head and swimming against the current...
The studs are non-tapered, 7/16" straight. I will need 7/16" rocker nuts.
Thanks so much.
Bob
  #672
Old 03-29-2015, 07:39 PM
You have an email.
Link here
http://paceperformance.com/i-6485769...r-package.html
  #673
Old 03-29-2015, 08:28 PM
Alvin's Avatar
Question
Slight off topic: Any links to where I can purchase press-in conversion to screw-in Pontiac stud kit? Looking for one of those old school kits that can be used with heads still in car and by removing valve covers, rockers, etc. only and was described as tap threader tool, matching srewin studs etc. Thxs in advance.
Return to topic: "Bent Wheel Bobs Excellent Y88 Adventure!"
  #674
Old 03-29-2015, 09:10 PM
Since the base of the Pontiac thread in stud is 7/16. It would make sense to go to a Big Block chevy straight type 7/16 stud so they can be adjusted easily like a chevy. BUt either way all you need a 7/16 bottom tap and the right number drill ( I have that info). I have used that conversion you speak of on a 71 head. The Pontiac threaded end of a stud will give you the depth and the amount above that is the total height including the nut. Hope this helps, FB
  #675
Old 03-29-2015, 11:12 PM
Alvin's Avatar
Project is 1973 4X 400 factory stock combo. Had been told that Mr. Gasket or (?) some company had a kit that included studs, taps, etc. to do the simple changeout. Reading Internet posts suggest machine work & other much more elaborate and detailed work needed?
Goal is to "Keep It Simple" with the changeout to retain #s matching & look. Perhaps I should just pull them send to SD...there goes that "mission creep?!!!"
Let's get Bob's Y88 thread back on track...
  #676
Old 03-30-2015, 11:42 AM
Well, after further consultation with Bruce it's obvious the stock type rocker nuts won't work with these PRW rockers. I have ordered some comp cam poly locks that are about 1/8" to 1/4" shorter and hopefully those in concert with a 5/16" valve cover gasket will do the trick. If not, I have also ordered a 3/8 billet spacer just in case.
Could someone check their car please and let me know how much clearance there is between the stock valve cover and the bottom of the pre-heater elbow. I would greatly appreciate it.
Thanks.
  #677
Old 03-30-2015, 09:03 PM
Alvin's Avatar
Arrow Please pardon our messy W72!
...Could someone check their car please and let me know how much clearance there is between the stock valve cover and the bottom of the pre-heater elbow. I would greatly appreciate it. Thanks.
Bob, I took 10 pix of that area from our 78 W72 for you...I can only load one image per post, so sorry in advance for multiple posts.
Was hard to even measure the gap - my WAG is between 1/4 & 3/8's inch was why I laid the tape over valve cover for you to see it's close and hard to get a good angle for photo & lighting.
Hope this helps you and what you are looking for? If not LMK and I'll be happy to take others for you.
P.S.: Please forgive our original messy engine bay
  #678
Old 03-30-2015, 09:04 PM
Alvin's Avatar
  #679
Old 03-30-2015, 09:11 PM
Alvin's Avatar
  #680
Old 03-30-2015, 09:13 PM
Alvin's Avatar
