Old 04-03-2015, 08:16 AM
bkmont's Avatar
bkmont bkmont is offline
Default 1968 Intake Condition Questions
Hello guys,
The original manifold has some pitting on the underside of the cooling water passage.
I don't see any rust through. The inside of the leg looks pretty good.
Should I be concerned?
Can I fill with a good epoxy?
Should I replace it? ( I really want to keep the original one on the motor)
Thanks,
Bryan
Old 04-03-2015, 10:19 AM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
Originally Posted by bkmont View Post
Hello guys,
Thanks,
Bryan
If you epoxy it it should be fine.
Old 04-03-2015, 02:15 PM
Clean the intake real good, sand/media blast it then use a good 2 part epoxy the same way you would use bondo & smooth it out with some sand paper then paint it & it will be ok.
Old 04-03-2015, 05:37 PM
steve v's Avatar
steve v steve v is offline
Since it's the bottom side of the intake & no one will see it I'd blast it, paint it & forget about it.
IF it ever starts leaking coolant (unlikely) then you can deal with it.
Old 04-03-2015, 06:13 PM
The Boss's Avatar
The Boss The Boss is offline
Blast it & paint it!
It's sand cast iron - it's uneven by nature.
And go racin' in the street.
Old 04-04-2015, 04:35 AM
bkmont's Avatar
Thanks guys. Done. It's blasted, sprayed and on the motor.
Talking about instant flash rust after blasting it. I used phosphoric acid to treat the flash rust and then sprayed it with epoxy primer until I get some Pontiac Blue.
The mock up is going well. It's helping consolidate all the engine parts instead of having them scattered all over the shop. I'll get serious with the engine resto after I finish the body work.
