OK, wasn't expecting to see the bearing in such good shape. Reaching at straws here, but I guess if there was a bad detonation event it had to happen just before the head gasket blew, and there wasn't enough of repeat cycle to wear and hammer away the Babbitt? At this point, that's just a WAG.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
My guess: How sure are you that the gasket wasn't marginally deformed at install? It might just be poor production QA that wasn't noticed.
"...ridge reamer and ring compressor? Do they have tools like that?" |
As long as these orange gaskets hold, I'm fairly confident there's also a 0.5 CR boost. The 4 spaces on the pistons tops don't come close to the surface area given up by using the 400 gaskets on a 350. I know they crush and I don't know how much, but I'll still bet the extra cc's given up with that huge lip when using a 400 gasket is more than the relief in the pistons. Thanks again for the input... I'm out of my league here in what to do next calling all the shots (I'd rather dump it off in a machine shop and pick it up when it's done). Last edited by thews; 07-22-2015 at 07:57 PM. |
I am using the Fel-pro gaskets in my current 350, so far so good. After ordering 3 sets of gaskets specified for a "350", I ended up with 3 sets that were about identical to the universal Fel-pro gasket.
Here's a pic of the Victor Reinz gaskets I received today (Part # 3401VC): ![]() There's an obvious egg shaped hole in the 350 gaskets vs. the 400 (Fel-Pro gasket pictured in the center). |
