Old 08-17-2015, 01:27 PM
hellerods's Avatar
hellerods hellerods is offline
Default A body driveshafts
Hi guys, will a 69 GTO ( 4 spd)drive shaft work in my 67' GTO clone ??( 455 with 400 auto short tail shaft) Thanks ahead of time for all your reply's and help Lee
Old 08-17-2015, 02:03 PM
No.
The 69 has a 3" shorter wheelbase than a 67.
Old 08-18-2015, 01:25 AM
But the Turbo 400 IS longer than the 4 speed. Try it and see. The yoke is different but the length might work.
Old 08-18-2015, 02:36 AM
Below are the stock driveshaft lengths used with stock Pontiac 8.2 10 bolts and stock 12 bolts. All are measured center to center on the ujoints. All T-400 application use the exact same '67-74 application med length T-400 yoke, not the shorty Seville yoke...
-'65-67 GTO M20, M21 60.00"
-'67 GTO Turbo 400 59.375"
-'68-70 GTO M20, M21: 56.00"
-'68-72 GTO Turbo 400: 55.375"
(same length with big output shaft Muncie or with 74 1/2+ 2nd design BW T-10)
Have several soap barrels at warehouse full of clean used late '60s early A body driveshafts.
With FedEx and OOPs outrageous oversize shipping, usually sell local, or drop off when on road trips.
Old 08-18-2015, 02:39 AM
sorry, too short
Old 08-18-2015, 12:04 PM
Kenth's Avatar
Kenth Kenth is offline
Also, 1968-72 4-door and stw with TH400 driveshafts should work.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
