Old 09-19-2015, 06:14 PM
rogerpgto rogerpgto is offline
Default 67 gto manual to auto conversion
What parts are needed to perform this conversion? Does the transmission cross member need to be moved? Which TH 400 needs to be used? Any specific guide linesd to be followed would be appreciated.
Old 09-19-2015, 06:18 PM
Move the crossmember back 6", the holes are already drilled in the frame.
You need a TH400 with the short (approximately 4" long) tailshaft extension.
Old 09-19-2015, 06:29 PM
400 4spd.'s Avatar
And it can't be from a Chevy. Buick/Olds/Pontiac will work. You also need the TH400 yoke, as the 4 speed is too small.
Old 09-19-2015, 06:35 PM
400 4spd.'s Avatar
Other things needed that I can think of,
Automatic radiator
Cooling lines and clips
Flex plate and correct bolts, yours are too long
Shifter, cable, retaining bracket for cable
Wide brake pedal, if you have power brakes
Caffiene to keep you awake once you start driving it with the automatic.
Old 09-19-2015, 06:55 PM
Scott Thelander's Avatar
Default Welcome
fairly straight forward conversion ... as stated from B-man
and 400 4spd .... you will find great help here and punctual help too...
have fun and be safe under there ...
pm sent
Scott
Old 09-19-2015, 09:47 PM
400 4spd.'s Avatar
I need all the help I can get, so don't hold back.
Old 09-19-2015, 10:27 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
One or more of the parking brake cables will have to be replaced as well as the hangers. I am not sure which one(s).And, if your radiator is not equipped with the cooling line hook ups you will need to change it or add an external cooler.
Old 09-19-2015, 10:54 PM
GOLDOHC GOLDOHC is offline
Default 400 - 400
I'm putting a 400 motor and 400 tranny in a 67 tempest. It came with a OHC 3 speed. Moved the tranny mount back, holes lined up. Had to shorten the drive shaft from, 60" to 59 1/4" used a 400 yoke. Tranny mount was different. Still working on e-brake. Put a lokar shifter and a ididit tilt column in.
Old 09-20-2015, 07:58 AM
Jeff Hamlin's Avatar
Thumbs down
BOO Hiss grumble grumble grumble
Old 09-20-2015, 12:16 PM
marxjunk marxjunk is offline
lol..
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 09-20-2015, 08:53 PM
Sorry Jeff
