What parts are needed to perform this conversion? Does the transmission cross member need to be moved? Which TH 400 needs to be used? Any specific guide linesd to be followed would be appreciated.
Move the crossmember back 6", the holes are already drilled in the frame.
You need a TH400 with the short (approximately 4" long) tailshaft extension.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
And it can't be from a Chevy. Buick/Olds/Pontiac will work. You also need the TH400 yoke, as the 4 speed is too small.
Other things needed that I can think of,
Automatic radiator Cooling lines and clips Flex plate and correct bolts, yours are too long Shifter, cable, retaining bracket for cable Wide brake pedal, if you have power brakes Caffiene to keep you awake once you start driving it with the automatic. |
fairly straight forward conversion ... as stated from B-man
and 400 4spd .... you will find great help here and punctual help too... have fun and be safe under there ... pm sent Scott |
I need all the help I can get, so don't hold back.
One or more of the parking brake cables will have to be replaced as well as the hangers. I am not sure which one(s).And, if your radiator is not equipped with the cooling line hook ups you will need to change it or add an external cooler.
I'm putting a 400 motor and 400 tranny in a 67 tempest. It came with a OHC 3 speed. Moved the tranny mount back, holes lined up. Had to shorten the drive shaft from, 60" to 59 1/4" used a 400 yoke. Tranny mount was different. Still working on e-brake. Put a lokar shifter and a ididit tilt column in.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
lol..
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Sorry Jeff
