#101
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
#102
I went 11.98 @ 109 @ 3680 w a 9.3-1 463 220 cfm dport.
xe284 dynod at 443 hp and yes it went flat at 4700 rpm. So with a better cam or springs it would have run better. |
#103
Do bee's bee?
#104
Car is coming along slowly but surely! My goal is to have it done and at the Nationals.
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
#105
PLEASE do not turn this into another XE bash thread. I noted that to indicate what a low compression car is capable of. |
#107
rpm intake,850dp,3000 converter,3.50 gears. |
#108
IMO it would be a pretty good combination. The XE cams close fast and help build cylinder pressure. I feel the XE284 is a decent choice with a 9:1 compression 455. Your converter and gear will match up good with that cam. You also have a good manifold and carb.
#109
You going to have it running this yr? Would love to see it/you at the track.
#110
My goal was always to get my heap to run as fast as your brothers iron 400. Being a 455,it should. Lots of goals,slow to get there,but i haven't given up hope yet.
#111
I have a ealmost exact duplicate of the "of" but a bullet grind. I am also running the crowed H.I.P.P.O lifters. I have the intake set at .006 and exhaust set at .008 cold. What is the lash everyone recommends?
#113
I think the consensus is going to be .006 on both. I just set my lash a few days ago and set it at .005. but am open to suggestions as well.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
#114
I had an almost stock 400 with #48's & it ran ok. I could get 13:02 @ 106 from it. When I decided to go faster I built a 462 (455 + .30) with new gears, 3:73's. I am running an M-22 now with the 462 E-heads right out of the box, a Crane blue print RA IV cam RPM intake & a Q-jet I reworked (800 cfm) RA round port exhaust & with almost no tuning, just what I did from the start to make it run correct, timming & carb adjust. I thought I did a good job of it & it went 11:77 @ 116. It idles at 800 rpm's with a good sound out the back of the exhaust & I can go just about any where with it I drives as even as it did when it was new. I have a few bucks in it But for what I have in it & the way it runs I love it. I don't have any fancy tunning involved in it & I can run on 87, but if I want to run it hard now I have to use 91 or 93 if I can find it. It went the 11:77 on 89 octane because thats what was in it when I got over to the track. I feel my biggest & best upgrade was the E-heads. Also this build is a FTC to.
#115
Can you post a photo of the cam card?
#116
#117
Thanks,its always nice to see everyone at the track.
#119
in regards to heat expansion, aluminum heads/iron block and the hybrid valve train, I too (like others) thought that lash would DECREASE (or close up) with heat, but is exactly the opposite.
so I set the lash cold at .003".....then checked them again hot. The result was the recommended clearance of .006". Valve train is virtually quiet now. |
#120
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
