#181
I very much doubt that was his intent
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
#182
Not at all, I don't know anything about you . I was just sayin.
#183
Hey Mike, can I ask what size pushrod do you use and has the pushrod hole been moved ?
Thanks and good luck this season. John |
#184
Sure. The pushrods are 7/16 to 3/8 taper .165 wall. And the intake rocker is .700 offset. So yes the pushrod hole was moved.
#185
Should be 1/2 straight imo.
#186
I agree. But no room in them lil heads.
#187
Ha ha.
#188
Valve hit the piston?
#189
Piston is OK. Valve, Guide was ripped out of head, Rocker arm junk obviously the spring and retainer. It's all fixed up. Just waiting on a head gasket.
#190
I thought it might be the guide or seat. Glad it's fixed, go get'em!
#191
Was the valve to guide clearance to tight? Making that must steam your egt's must expand that valve a bunch.
#192
Not sure why spring broke.....
#193
What springs you running? Did the dyno let go of the engine at any point? I've broke a couple PAC double springs from the dyno letting go.
#194
Great thread Mike. Very pertinent info. Thanks for the many details. Best of luck with the dyno session; Looking forward to some top level numbers.
Jim www.raceV8s.com 1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th. |
#195
Sometimes you just happen to be the guy that gets the part that is not perfect and then you have an issue. Especially when the part is "exercised" like Mike is doing his deal.
Keep after it Mike! Tom V.
#196
I asked this because of the adjacent valve in the photo- the non-concentricity of the retainer with the O.D. of the top of the spring is visible. So the retainer's shoulder must not be a snug fit in the spring I.D. This, in combination with the skimpy retainer O.D. and cross section in that area (considering the extreme loading), would cause me to suspect retainer failure.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
#197
Mike,
Your car has progressed quite a lot over the last few years. Can you talk about what you've used fuel-wise from being a mid nine second combo to what it is now? |
#198
Back in the day with the 477 that was 13.7 cr we ran c14. We tried q16 In 2010 with good results. Still running it now. There are fuels that show more power but they are risky imo.
#199
Back on the pump again!
#200
Good luck
