#2761
Old 03-18-2016, 09:55 AM
bird72's Avatar
bird72 bird72 is offline
Maxilo, I am doing an HO, but as Pinionhead and HO said on #'s, parts & cost..... If not hung up on matching numbers and dates, any early 70's 2 bolt 455 will be already drilled for 4 bolt, and rather than a spendy & hard to find "HO" block, 4 bolt caps can be added to a 2 bolt block (what I did) on a YC 1971 block (align bore rqd.). I spent 2000 on 71 HO heads and 700 on 71 intake. Had block and all misc parts also. I expect to have $6-8000 in build maybe when done on top of heads & intake parts cost, so 10K engine ballpark maybe. Forged psitons and rods and roller valvetrain is almost half of that cost. A "stock parts" build could be substantially less. Yes I will have a "mutt" engine but do not care, it will make equal fun as any.
72 Bird
  #2762
Old 03-18-2016, 12:33 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
Way to go Rick, I had forgotten about that posting. It already on his side of the pond.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
  #2763
Old 04-11-2016, 10:46 PM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
Thumbs down 1971
...lots goin on here with this one but unfortunately a good portion of it looks like it needs correcting....
http://cgi.ebay.com/ebaymotors/Ponti...JXB~Jw&vxp=mtr
  #2764
Old 04-11-2016, 11:53 PM
Formulabruce's Avatar
Always fun to guess about what "type" of shop "restored" a car...
This one has MOPAR Shop all over it, just like the white paint! ( it is one step above undercoating though LOL)
" Long may we DRIVE !"
  #2765
Old 04-12-2016, 01:11 AM
HO Kenny's Avatar
HO Kenny HO Kenny is offline
I didn't know MOPAR guys painted their cloth door panels, or used the wrong year seat covers when correct ones are available. Wrong year lower door panels I sort of understand because correct ones are hard to find. I do know they like hood pins. I hate hood pins. Looking at the guage the gas tank must be really big.
  #2766
Old 04-12-2016, 02:03 AM
2manyT/A'S's Avatar
The white under carriage looks bizarre.......
The mopar guys used to LOVE yellow plug wires....
Door panel uppers are 73-74 double deluxe.....
Whoever buys this car will not know ANYTHING about Pontiacs....and LOVE it.....
Eye Candy......garage band?
Go full screen & turn it UP!
  #2767
Old 04-12-2016, 04:32 AM
Crap Kenny, I was still on the outside with the one body color!!
  #2768
Old 04-12-2016, 09:51 AM
71HOT/A 71HOT/A is offline
Judging by the left quarter wheel opening I'm done.
  #2769
Old 04-12-2016, 09:57 AM
RamAir's Avatar
RamAir RamAir is offline
I saw this car In Tampa at the Vicari auction last week. Run don't walk away lol
  #2770
Old 04-12-2016, 11:54 AM
HO Kenny's Avatar
To be fair., if I was buying a MOPAR there are lots of things that could be incorrect and wouldn't know. Like, an ironing board for a rear spoiler.
If the bones of the TA are solid, other than the stupid hood pins, the faults I see could easily be corrected. I Hate hood pins.
  #2771
Old 04-12-2016, 11:57 AM
bird72's Avatar
now I have seen a white bottom bird...
72 Bird
  #2772
Old 04-12-2016, 03:26 PM
2manyT/A'S's Avatar
Actually.....most of the cars that ran in the SCCA Trans am series had the undercarriages painted white or grey......including the late great Jerry Titus's #8......Made oil and coolant leaks easier to spot quickly...in a pit stop..
  #2773
Old 04-12-2016, 04:31 PM
maxilo maxilo is offline
[QUOTE=RicksGTO;5549394]Maxilo, here is an engine I remembered seeing a few months ago on a youtube video in England, not sure if he'd sell it separately but it was an extra engine so might be available? The engine comes in at about the 5:00 minute point of the video... https://www.youtube.com/watch?v=n8cZW8jfZqM[/QUOTE
Old 04-13-2016, 07:52 AM
Judge273's Avatar
Judge273 Judge273 is offline
Is this rare? Never seen anything like it before?
http://forums.maxperformanceinc.com/...d.php?t=789140
Mike/Illinois
  #2775
Old 04-13-2016, 10:07 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Yep, rare as hen's teeth Mike. 1972 455HO fitment only. PN 487196 for the thermostat coil.
Regards,
"455HO" Lloyd
  #2776
Old 04-14-2016, 11:08 AM
bird72's Avatar
A bit of bad news on HO build, after disassembly of 455 block, hard use 20 years ago showed bad spot on main on crank one location, bearing failure of some sort. Looks salvageable, will have machinist report on in a few days.... Question for y'all: for a quality build, would you have issues with using a turned down crank or would you buy a Butler (Eagle?) new one? Is 71 factory crank now...
72 Bird
  #2777
Old 04-14-2016, 11:21 AM
goathead455 goathead455 is offline
Grind the factory crank unless you want to step up to a forged one.
The factory piece is far superior to the new cast cranks in my opinion.
  #2778
Old 04-14-2016, 11:30 AM
Lloyd-TX's Avatar
Thumbs up
My thoughts exactly.
Not a thing wrong with machining and polishing the factory piece. They're TOUGH!
Regards,
"455HO" Lloyd
  #2779
Old 04-14-2016, 11:57 AM
bird72's Avatar
that was my gut feeling THX
72 Bird
  #2780
Old 05-07-2016, 10:11 AM
bird72's Avatar
So THX to a great member here for a crank. Local machinist just did complete diagnosis that explained motor history. Bottom end was built 20+ yrs ago.
Bad align bore when 4 bolt caps added then.
Bad piston clearance ring to bore.
Result very bad crank scarring one spot and scuffed forged pistons. I used a Chevy racer machine shop guy in Oregon. Bonehead errors. Bad move I guess. I did hammer on that engine.
Good news is Matt's HO heads reported as "very nice".
Very happy with my machinists diligence. Block off to be align bored properly.
Anyone here use Cliff Rugles round port roller cam? Custom grind he recommends. Impressive dyno sheet on an SD. Nice power sub 5500.
72 Bird
