Old 04-23-2016, 06:28 PM
Held for Ransom's Avatar
Default The game
Well, since I didn't go to the Jefferson Swap Meet this weekend, let's see if you can guess what I did do. The un-fun part was having to post in this section.
Pictured is a Pontiac air cleaner. Can anyone tell me the year and application? Breather hole edge is 15" from the edge of the snorkel.
ID:	426918   Click image for larger version
ID:	426919   Click image for larger version
Old 04-23-2016, 08:36 PM
74 SD455 Formula 74 SD455 Formula is offline
1974 ?
Old 04-23-2016, 10:39 PM
TA455HO's Avatar
TA455HO TA455HO is offline
I'm seeing a date code on the Wittek tower clamp of 1/72. If that's correct it has to be a 72 year. Too late for 71 and too early for 73.
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
Old 04-23-2016, 11:19 PM
Bentwheelbob's Avatar
I think the Wittek clamp is a decoy. I am really just learning these cars, but I don't think a single snorkle air cleaner like that with provisions for the left fender air intake duct was available until '73. The flapper pin orientation matches Mike's rule of thumb for 1974, so that is my guess.
Old 04-24-2016, 12:56 AM
That one looks like the one I have hanging on my wall & it's a 73 , the original one off my 73 GTO. The end would point towards the left fender & have the fuzzy hose going to a feed under the battery box.
Old 04-24-2016, 05:01 AM
Really Bob, look at your air cleaner and the pictures again.
Old 04-24-2016, 09:35 AM
PQ decal = '73.
Old 04-24-2016, 10:08 AM
What kind of '73?
Old 04-24-2016, 01:01 PM
marxjunk marxjunk is offline
With a drain hole in the bottom it's shaker or someone made it up
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 04-24-2016, 04:26 PM
you went to that auction
Old 04-24-2016, 05:10 PM
Where else you going see a mudded '72 GTO (white w/green guts, column shift) with a '69 WW block sell for over $20K (taxes and buyers fee). Did you know someone that was there other than me?
Old 04-24-2016, 05:17 PM
I'm pretty sure that is a Firebird air cleaner. If you look at how deep the surface is the air cleaner sits on relative to where the carb sits, you will see there is a big drop down. That is typical of 1970 and up Firebirds.
The type of snorkel is made to duct over to the core support, so it would be a 73 and up.
I'm guessing it is a Formula Firebird base or possibly a Trans am air cleaner base.
I didn't see a drain hole, but I saw the carb vent that Pontiac Q-Jets used starting in 1971.
Mike
Old 04-24-2016, 05:28 PM
First picture Mike.
Old 04-25-2016, 03:30 PM
Transamric's Avatar
Is the clamp date 1/72 or 11/72? I think I am seeing a faint 11 before the hash mark.
Old 04-25-2016, 03:52 PM
Transamric's Avatar
Ok, I'll chime in with, it's a '73 Trans Am L75 base that Bob really needs to replace his '74 base??
Old 04-25-2016, 04:22 PM
It's a 1/72.
Old 04-25-2016, 04:58 PM
Automatic transmission TA built prior to 3/15/73.
If I get it right can I have the white stripe vacuum hose? I understand I need one and would prefer one with a little patina.
Old 04-25-2016, 06:08 PM
necdb3's Avatar
necdb3 necdb3 is offline
The TCS is 73
Old 04-25-2016, 07:30 PM
With air conditioning...
Old 04-25-2016, 09:14 PM
Formulabruce's Avatar
Its an early 73, I will agree. sticker location is a bit puzzling
" Long may we DRIVE !"
