Old 05-19-2016, 11:26 AM
77 TRASHCAN's Avatar
Originally Posted by Torquewar View Post
The 20th will be fun with TA man and CNC. The trio of second gens will make there presence known.
Darn weather better co-operate...
How's the weather looking for tomorrow? Gonna have to mount your mud grips?
Shut it off
Shut it off
Old 05-19-2016, 02:43 PM
ta man ta man is offline
Weather looks good..Sunny and 70 degrees in the afternoon..won't need my snow tires,also swapping the skis on the front for my skinny Welds/Mickey SR's....just need to shovel the car out from the snow bank and I'm good to go!
Old 05-20-2016, 10:47 AM
Pontiac Derek Pontiac Derek is offline
Awesome, good luck Dude!
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
Old 05-21-2016, 02:13 AM
Well we all had a good night at the track....everybody that was with us ran quicker, a Cpl fresh builds with no issues.As always traction was the key at this track.....my first run was my new best...11.30.18 at 120.58 with a 1.6509 60ft...next 2 runs were traction impaired but both over 120mph....my last run of the night..sorta surprised me...we thought the track was getting slippery..after a big burnout..ran 11.3223 at 121.35 with a 1.6798 60 ft with a slight spin.The car is definitely making more overall power..only once before has it ran in the 120's and that was wind aided.The only part that was changed from last year was the intake..jetting and timing remained the same...I did change the front squirter on the carb after first run...the car may pick up slightly with perfect traction..Big thanks to Pontiac Derek for the porting of this intake..it increased topend power but also kept the big fat torque curve.
Old 05-21-2016, 09:11 AM
goathead455 goathead455 is offline
What rack were you running at ?
Old 05-21-2016, 09:39 AM
St Thomas Raceway Park
Old 05-21-2016, 01:15 PM
The Pleasure was all mine! I did not expect you to pick up a tenth out of the gate! Keep tuning on her and i am sure you will reach your 11.20 goal!
That 121.35 indicates that, Im here should you need anything at all!!!
Thanks again Ernie!!!
Old 05-25-2016, 12:54 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Awesome progress and damn impressive MPH too ! What is your RW ?
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 05-25-2016, 06:46 PM
I will weigh it soon..the old 80 TA weighed right at 3910lbs with me in it with half a tank...I haven't weighed the new car..it may come in at 100 lbs lighter,has a fiberglass hood,RobbMc starter,15 lb battery..and 15 X 4 Draglites with 165/85 M/T SR's...but has a lot of Dynamat..
Old 05-26-2016, 04:15 PM
So Ernie,
I believe you've mentioned here, or another thread about getting you car into the 10's. What's your thoughts about what path you might take to get there???
I'm asking this, as you are ironing out your return to the T2 intake, and such...
Shut it off
Shut it off
Old 05-26-2016, 02:11 PM
Yeah and he Hit 121.35 mph on one pass!
