#321
Old 06-19-2016, 11:11 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by slowbird View Post
Fyi, there are guys running well into the 10's with 3.42 gear, most likely would still run tens with 3.08.
^^^Truth^^^
Go fast, see Elvis!
  #322
Old 06-19-2016, 11:17 PM
PAUL K's Avatar
Why mess with a perfect street performance combo?
A 400 stroker with a 3-speed auto, doesn't get much simpler than that.
Runs 11.20s with 3.08 gears.
Great out on the highway and the track too.
Drive it anywhere, anyplace, any time.
Not many guys ever achieve this, hopefully more will carefully study this thread and follow suit..
I agree, but you always have to keep hunting for that next tenth.
Go fast, see Elvis!
  #323
Old 06-20-2016, 08:46 AM
ta man ta man is offline
Originally Posted by Chicagogoat View Post
You still haven't hit the ceiling with that combo yet! I wonder if you can get close to 11 flat with your current cam, converter, and gear. On paper, a non Pontiac guy would say that you're under cammed/geared. Many other street Pontiac guys do the same thanks to repeated tuning, dyno or track outings. What does that say about Pontiac?!
At the start of the year I thought maybe low 11.2's..end of this year...after the last outing in warm weather..I'm thinking 11 flat is doable.On my quickest run I had a pretty good hesitation on launch..I'm thinking I can get my 60ft down close to 1.6.With a couple other minor tweaks..maybe knock a another tenth off the et....so it may get close..
  #324
Old 06-20-2016, 08:50 AM
Originally Posted by 71 T/A View Post
TA Man could go to 3.42 gears and a little more stall like 3500-3800. Of course that means more traction would be needed. You're never done in racing and that's a good thing.
Yes that's a given with traction more stall and gear would get it there..I'm enjoying the tuning process too much ....trying to get as much out of the basic combo as I can.
  #325
Old 06-20-2016, 08:59 AM
How much does the rear and passenger seats weigh? And the front sway bar? Bet you would get the 2 tenths that way, that's probably close to 100 lbs.
  #326
Old 06-20-2016, 09:17 AM
Nice idea..I still like it looking like a car inside!Would probably take 200lbs for 2 tenths....I've thought about the swaybar and may try it again...the old car I took it off for a bit..I like how it handles and leaves flat with it on..but weight is weight..and it may help the launch a bit...I know if I'm knocking on 10.99 the seats will come out!
  #327
Old 06-20-2016, 09:21 AM
I did back to back on my TA just with the sway bar unhooked not off and no difference in hooking and sure did sway making the turn around at the end of the track.
Front skinny tires made a bigger difference than just the weight loss with them I guess rolling resistance.
  #328
Old 06-20-2016, 09:29 AM
I like my front skinnies..was part of the front end weight loss program...mini starter,battery and wheels and tires...
  #329
Old 06-20-2016, 10:53 AM
wheneaglesfly wheneaglesfly is offline
I notice we never do Racing math here on Max.
And I like All engine parameter math, calculus, & drive train math.
Break it down so all can understand.
Coming up next.
  #330
Old 06-20-2016, 11:06 AM
The engine is a Hot Street Strip 455 -463 with modern aluminum race heads, stump puller torque cam, 575 ft/lbs peak torque at the flywheel.
Rear diff Gear. Turbo 400 1st gear . 575ft/lbs flywheel torque.
__________________________________________________ _______
3.08 X 2.48 X 575 = 4,392.08 ft/lbs delivered to rear tires- pavement on launch.
3.23 x 2.48 x 575 = 4,605.98 ft/lbs
3.42 x 2.48 x 575 = 4,876.92 ft/lbs
3.64 x 2.48 x 575 = 5190.64 ft/lbs
3.73 x 2.48 x 575 = 5318.98 ft/lbs
3.90 x 2.48 x 575 = 5561.4 ft/lbs
4.10 x 2.48 x 575 = 5846.6 ft/lbs
4.30 x 2.48 x 575 = 6131.8 ft/lbs
4.33 x 2.48 x 575 = 6174.58 ft/lbs
4.56 x 2.48 x 575 = 6502.56 ft/lbs
  #331
Old 06-20-2016, 11:12 AM
4.88 x 2.48 x 575 = 6958.88 ft/lbs
5.13 x 2.48 x 575 = 7,315.38 ft/lbs
5.38 x 2.48 x 575 = 7,671.88 ft/lbs
5.57 x 2.48 x 575 = 7,942.82 ft/lbs
5.86 x 2.48 x 575 = 8,356.36 ft/lbs
6.14 x 2.48 x 575 = 8,755.64 ft/lbs
  #332
Old 06-20-2016, 11:17 AM
2.41 x 2.48 x 575 = 3,436.66 ft/lbs
2.56 x 2.48 x 575 = 3,650.56 ft/lbs
2.69 x 2.48 x 575 = 3,835.94 ft/lbs
2.73 x 2.48 x 575 = 3,892.98 ft/lbs
  #333
Old 06-20-2016, 11:24 AM
The gear I would choose gives an instant 28 % torque increase to the pavement blacktop.
Engine is never touched.
  #334
Old 06-20-2016, 11:39 AM
ponjohn's Avatar
ponjohn ponjohn is offline
My old ventura had a rack conversion and no sway bar at all. It was scary on long sweeping turns, it would push.
That car was meant to do one thing, go straight.
  #335
Old 06-20-2016, 01:11 PM
So is that the general/baseline math, 10th of a sec for every 100 lbs?
Thing with gears, cam selection needs to be in line for any gain there. Isn't it something like you want to be a peak HP RPM as you cross the line?
  #336
Old 06-20-2016, 01:12 PM
That's still better than Chevy IIs, those things always go towards the wall!
  #337
Old 06-20-2016, 01:49 PM
Ideally Yes.
You want to be at Peak HP At 1320 foot mark.
Or at 1000 foot mark and cross 1320 mark 200-400 rpm.
Over.
Not over rev the engine.
Hydraulic Roller cams don't like being over revved.
Stuff breaks fast.
  #338
Old 06-20-2016, 01:52 PM
Big torque engines like Pontiacs can cheat some.
But chasing down Tenths with available parts now.
Weight reduction can be done also.
Becomes less of a street car.
More like a gutted Race Car.
  #339
Old 06-20-2016, 01:54 PM
Then a Taller rear tire can be used with a Lower gear ratio.
MPH Trap speeds increased in theory.
Big End MPH 800-1320 target goal.
ET reduction should follow.
  #340
Old 06-20-2016, 02:43 PM
Transmission/Gear 1st 2nd 3rd 4th 5th 6th Reverse
Powerglide 1.76 1.00 - - - - 1.76
Powerglide 1.82 1.00 - - - -
TH200-4R 2.74 1.57 1.00 0.67 - - 2.07
TH350 2.52 1.52 1.00 - - - 1.93
TH400 2.48 1.48 1.00 - - - 2.00
TH700-R4 3.06 1.62 1.00 0.70 - - 2.29
4L60 / 4L60-E 3.06 1.62 1.00 0.70 - -
4L80E / 4L80-E 2.48 1.48 1.00 0.75 - -
C4 & C6 2.46 1.46 1.00 - - -
727 2.45 1.45 1.00 - - -
904 2.70 1.54 1.00 - - -
Borg-Warner T56 2.97 1.94 1.35 1.00 0.84 0.62 3.38
