That car was meant to do one thing, go straight. |
So is that the general/baseline math, 10th of a sec for every 100 lbs?
Thing with gears, cam selection needs to be in line for any gain there. Isn't it something like you want to be a peak HP RPM as you cross the line? .
You want to be at Peak HP At 1320 foot mark. Or at 1000 foot mark and cross 1320 mark 200-400 rpm. Over. Not over rev the engine. Hydraulic Roller cams don't like being over revved. Stuff breaks fast. |
Big torque engines like Pontiacs can cheat some.
But chasing down Tenths with available parts now. Weight reduction can be done also. Becomes less of a street car. More like a gutted Race Car. |
Then a Taller rear tire can be used with a Lower gear ratio.
MPH Trap speeds increased in theory. Big End MPH 800-1320 target goal. ET reduction should follow. |
Transmission/Gear 1st 2nd 3rd 4th 5th 6th Reverse
Powerglide 1.76 1.00 - - - - 1.76 Powerglide 1.82 1.00 - - - - TH200-4R 2.74 1.57 1.00 0.67 - - 2.07 TH350 2.52 1.52 1.00 - - - 1.93 TH400 2.48 1.48 1.00 - - - 2.00 TH700-R4 3.06 1.62 1.00 0.70 - - 2.29 4L60 / 4L60-E 3.06 1.62 1.00 0.70 - - 4L80E / 4L80-E 2.48 1.48 1.00 0.75 - - C4 & C6 2.46 1.46 1.00 - - - 727 2.45 1.45 1.00 - - - 904 2.70 1.54 1.00 - - - Borg-Warner T56 2.97 1.94 1.35 1.00 0.84 0.62 3.38 |
Overall First Gear Ratio :
1 (Tranny Ratio x Rear Gear Ratio) This indicates the mechanical advantage your car will have coming off the line - higher number is better (up to a point) Tranny/Rear Gear 2.41 2.56 2.73 3.08 3.23 3.31 3.42 3.55 3.70 3.73 3.91 4.10 4.56 PowerGlide 4.24 4.51 4.80 5.42 5.68 5.83 6.02 6.25 6.51 6.56 6.88 7.22 8.03 TH200-4R 6.60 7.01 7.48 8.44 8.85 9.07 9.37 9.73 10.14 10.22 10.71 11.23 12.49 TH350 6.07 6.45 6.88 7.76 8.14 8.34 8.62 8.95 9.32 9.40 9.85 10.33 11.49 TH400 5.98 6.34 6.77 7.64 8.01 8.21 8.48 8.80 9.18 9.25 9.70 10.17 11.31 TH700-R4 7.37 7.83 8.35 9.42 9.88 10.03 10.47 10.86 11.32 11.41 11.96 12.55 13.95 4L80E 5.98 6.35 6.77 7.64 8.01 8.21 8.48 8.80 9.18 9.25 9.70 10.17 11.31 Borg-Warner T56 7.16 7.60 8.11 9.15 9.59 9.83 10.16 10.54 10.99 11.08 11.61 12.18 13.54 |
