Old 06-23-2016, 07:39 AM
1979birds 1979birds is offline
Default 61/63 tempest 4cly engine
Looking for a 4cly engine for my 62 lemans.
Old 06-23-2016, 09:44 AM
jusjay's Avatar
jusjay jusjay is offline
check with 63banshee on this site.
Old 06-23-2016, 10:27 AM
marxjunk marxjunk is offline
i see them often on craigslist..you just have to be diligent...use something like searchtempest.com
you can do a search for X amount of miles from your location..or coast to coast
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 06-23-2016, 12:01 PM
trynsave trynsave is offline
61 62 4 cyl engines are slightly different from 63
Old 06-23-2016, 12:49 PM
Thanks what are the differences.
Old 06-23-2016, 01:00 PM
front cover..cam among other things ..maybe inside of block-but you can still bolt a 63 into a 62 and vice versa
Old 06-23-2016, 06:57 PM
68Prix's Avatar
68Prix 68Prix is offline
I have a 62 if you're interested. PM me if interested.
Old 06-25-2016, 11:01 PM
GaryK's Avatar
GaryK GaryK is offline
61 and 62 have a thicker wall blocks where 63 are thinner. If you are not going to build a race motor out of it, it really doesn't matter.
61-2 used a flat top pistion in the 10.25:1 4 cylinders and dished in the 8.6:1 motors, 63 all were flat tops and the difference in compression ratio was with the head.
61 had a different 4bbl intake than the 62-3's.
63 has the alternator bracket.
I put a 63 motor in a 62 Tempest, everything will bolt up.
Gary
Old 06-26-2016, 06:59 AM
62 and 63 camshafts are not interchangable
Old 07-02-2016, 09:36 AM
GaryK's Avatar
What are the differences? I never heard this before.
Old 07-02-2016, 01:09 PM
its been 30 years since I built one..so my memory isn't real clear-but I think the rear cam journal is larger
Old 07-03-2016, 09:55 AM
c5farmer's Avatar
c5farmer c5farmer is offline
Default T4 camshafts
The Pontiac parts manual list the camshaft number for 61-63 T/4 engines with the same cams...pn 539099 (J) for dual valve springs and pn 537995 (H) for single valve springs. They are interchangeable. Same cams were used in all 3 years.
Old 07-03-2016, 10:34 AM
ok-like I said.... 30 years ago-I just remember the something wasn't the same inside the block
Old 07-04-2016, 10:56 PM
c5farmer's Avatar
Default Agree
Trynsave, I forget stuff a lot quicker than 30 years ago ! You may have been thinking about the way Pontiac controlled the compression ratio in the 4cylinders. 61-62 it was controlled by the piston domes and 63 by cylinder head combustion chamber size.
About the only differences I know of.
Old 07-04-2016, 11:04 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
I have a couple of engines, also a nice build in the process.
Call me if you want to discuss.
Calvin Hill
Hill Performance
708-250-7420
