Now parting out this engine. Heads have sold. Everything else available at this time.
400ci 'WT' Block: Casting #9786133, Date code D247 Had it inspected at my local machine shop, has a repairable water jacket crack on the rear left side. Was quoted $200-$300 to fix. One cylinder will also need a sleeve do to a few pits. Quoted $180 to install. A normal .030 over will clean up the rest. Have main caps also. $200 +Plus shipping Crank: Original 'N' nodular steel, Casting #9773524. Cleaned, needs a normal .010 cut. $150 Shipped Pistions/rods: Pistons will obviously need to be replaced. Rods are in good shape. Need standard reconditioning. $80 shipped Intake: Casting #9786286, date code D197. Cleaned/primed. Nice shape. $120 shipped Distributor: Correct part #1111250, Date code 7D20. Needs rebuild. $100 shipped Alternator: Correct part #1100704, Date code 9C20. Needs rebuild. $80 shipped Power steering: Correct part #9786901XH on pulley. Needs rebuild. $125 shipped Power steering bracket: Correct part # 9786903. Cleaned, good shape. $40 shipped A/C compressor lower mounting bracket: Part #9789228. Cleaned, good shape. $40 shipped water pump: Correct part #PH-262, Date code ? Needs rebuild. $30 shipped water pump pulley: 2 groove, #9786909XJ. Good shape. $25 shipped Crank Pulley : 2 grove, good shape. $25 shipped Bellhousing: Cleaned, has shift fork/ball, good shape $125 shipped Oil pan: good original, $50 shipped. Timing cover: Correct part #9783130. Cleaned, needs top mounting tab repaired, some corrosion behind water pump area smoothed out. $50 shipped Rockers with hardware: $40 shipped Misc. small parts, bolts, hardware sets, $15 shipped |
