Old 09-28-2016, 03:35 PM
Mike Davis's Avatar
Default LS swap in 66 A body
Might not be the correct place to put this but it is 66 A body specific.
Has anyone done an LS swap in a 66 GTO?
If so what obstacles etc?
Not looking for a debate just real life info
Thanks in advance--
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 09-28-2016, 03:48 PM
arbys's Avatar
arbys arbys is offline
Oh the comments you will get.
Old 09-28-2016, 03:58 PM
Mike Davis's Avatar
I know-- but I have flown the Pontiac Flag and have raced Pontiacs since the late 80's.
Been one of the last Pontiacs running in NMCA NSS class for the last 13 years.
Haved raced many Pontiacs in different classes. From a 455 Powered Sunbird, 1LE Formula SS Car, 73 Formula Firebird.
Getting hard to justify the expenses to compete in this class with availability of parts (IE 2x4 intakes, blocks, carbs)
New class for GM cars-
Sealed GM performance parts LS DR525, 55-up GM Body, heads up, pro tree.
Be cheaper to swap to LS power than build new car.
421 CID
Old 09-28-2016, 04:02 PM
Tim john Tim john is offline
You can find LS swap mounts at DSE (Detroit Speed & Engineering). Holley/Hooker also makes LS swap headers for your application, their "Blackheart" series in mid length and long tube also in stainless. Dirty Dingo also makes a LS swap mount. You have many options for this swap application. Check out the "Lateral G.com" forum & the "Pro Touring.com" forum as well, tons of information for you on these. Speartech.com is who you can trust for your wire harness and computer re-flash. They can rework your original engine harness or build you a new one. If you need additional information just let me know.
Tim john---
Old 09-28-2016, 07:26 PM
S Courter's Avatar
S Courter S Courter is offline
Mike This is a relatively easy swap. I did it in my 64 Tempest and am going to do it in my 65 Lemans this winter. Lots of options out there for mounts, exhaust, fuel systems, etc. I used BRP hotrods mounts and headers in the 64 but am going to use adapter plates and chevy SB mounts this time to cut costs. Will build trans mount based on the BRP mount in the 64. Here is a link to BRP if you want to check their offerings. If I can help in any way let know.
Steve
[email protected]
http://www.brphotrods.com/mm5/merchant.mvc
Steve
71 Pontiac GT-37 400 4 spd (sold)
71 Formula 400 turbo 400 (sold)
01 Firebird T/A WS6 auto (fun)
64 Tempest Post car LS1/4L60E (Love It!)
65 Lemans Post car LS1/4L60E (More Fun)(sold)
73 Lemans GT 400/auto 1 owner 52k miles
69 El Camino LS1/4L65E (Awesome)
70 Pontiac GTO Convertible 400/400 Original (sold)
69 Olds Cutlass S W31 Numbers matching 4Spd 3:91 one of 569
72 Post Coupe GTO 400/400 1 of 60 built 1 owner original
Old 09-30-2016, 07:36 PM
andrewb70's Avatar
andrewb70 andrewb70 is offline
Best system on the market for LS swaps is made by Holley. They are about to release the early a-body parts.
Andrew
IG: projectgattago
Please get in touch for Holley EFI tuning services.
"You were the gun, your voice was the trigger, your bravery was the barrel, your eyes were the bullets."
Old 09-30-2016, 10:04 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Just did this at a shop up in Baldwin (Cornelia), GA. They finished the car one day and the next day he drove it to Seattle, Washington without a hiccup. PM me if you want any more info.
Old 10-03-2016, 02:19 PM
old66tiger's Avatar
old66tiger old66tiger is offline
LS3 in my 66 GTO. Search my post out here, LS1 tech and pro-touring forum ...ask questions...as Andrew said, Holley is in the game with a kit that takes the guess work out. I did mine before the kit existed so you can price each out and decide which way to go.
Sent from my LGUS990 using Tapatalk
Skinned knuckles and empty wallet! Could I be any happier?
66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front).
2002 Ram Air WS.6 convertible Trans Am. Wife's car.
Old 10-13-2016, 10:52 PM
Poppy's Avatar
Poppy Poppy is offline
Pretty straightforward actually. Change the radiator and use electric fans, upgrade your wiring to handle the demands of the fuel pump and fans and provide clean power to your ECM.
Steve
1964 Lemans
