#521
Old 10-15-2016, 11:13 PM
pontibeast's Avatar
pontibeast pontibeast is offline
Originally Posted by ta man View Post
New best timeslip...may be hard to beat until next year..good traction,cool air and no driver error!
What type of roll cage are you running?
  #522
Old 10-15-2016, 11:16 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Great job!
Go fast, see Elvis!
  #523
Old 10-16-2016, 11:13 AM
78w72 78w72 is offline
thats awsome taman! i had a new best last weekend too but they are done for the year at my dragstrip. next spring im hoping to come close to 11.1's! my best so far is 11.28 at 122mph. best mph so far is 123+.
can i ask what your launch technique is? i see you tried a 2500 rpm launch & got best 60ft's. so far i can only launch off idle or maybe 1100rpm & can only graduallly hit WOT. if i hold it to say 1500 & reallly mash teh pedal i just spin my tires. very frustrating as i know theres more in the car but i cant get an ideal launch. average 60ft is 1.70 but my best last weekend got a 1.65. my car has zero traction aids, 255/60 m/t et street radials & a super stiff road race type suspension... that is killing the times im sure! any tips on how youre launching the car & what traction aids do you have? i am considering cal-tracs & maybe a little wider tire.
great times, 10.99 isnt far away!
  #524
Old 10-16-2016, 11:36 AM
Great work!
  #525
Old 10-16-2016, 12:21 PM
rt400 rt400 is offline
Default where to buy?
I have been looking for 308 ring and pinion for 8.2 BOP style rear end. No one seems to produce an after market ring and pinion for that type rear end. Anyone know where I could find one or who may produce one. All I find is a Chevy style that would require a yoke change. Thanks in advance.
  #526
Old 10-16-2016, 12:24 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
a good example why not to run a 750 carb on a +4 fity 5..
Congrats!!
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
  #527
Old 10-16-2016, 01:35 PM
ta man ta man is offline
All I have for traction aids are cheap 3 way CE shocks 90/10 front 50/50rear,my car has stock suspension and actually is fairly stiff.I normally launch from idle and hit the convertor hard..with my old car I found the same as you from a higher launch it would spin..so I have been launching from idle or just above for years and that was carried over to the present car.I've been fighting a small hesitation upon launch...so I thought I'd try stalling up the car..and it seems to work as long as the track is decent.
Another point I can add is I'm now running 275/60/15 et pros and they are a better tire than the old et streets..you don't need as much burnout..and when I slightly spin I still run a decent et..instead of smoking the tires bad..
  #528
Old 10-16-2016, 01:49 PM
What tire size are you wanting to run?I run a 275/60/15 with a 3.08...just use a rpm calculator to find a tire size and a available rearend ratio that is close..
  #529
Old 10-16-2016, 02:21 PM
thanks for the launch info, i may try stalling up a little higher next time out. i will be looking into new tires soon but still have some life in these. i do have some cheap summit 3 way adj shocks but thats it. the PTFB GT suspension kit if just too stiff for any real drag use. but i built the car with a multi purpose in mind, street, strip & some corner carving.
might try a different intake too just to see if there is any improvements over the SD ported cast iron im running now... if anything just to get that 40lb hunk of iron off the nose!
  #530
Old 10-16-2016, 04:50 PM
ponjohn's Avatar
ponjohn ponjohn is online now
IMpressive again.
11.ohs with 3.08.
  #531
Old 10-16-2016, 05:00 PM
Just the weight off the nose can help a lot...my battery and starter weigh 23 lbs total!I'm using a little Braille 2015 battery weighs 15lbs!
  #532
Old 10-16-2016, 08:14 PM
Half-Inch Stud Half-Inch Stud is online now
...might try a ported Torker I. :~|
  #533
Old 10-16-2016, 08:20 PM
ta man, looks like you are really doing something good with tuning. 11.04 @ 123.6 is fantastic! With a 3.08 gear set is again fantastic!
  #534
Old 10-16-2016, 08:50 PM
yeah im considering the braille battery too. how has yours been working for the last year or so since you got it? i already have a mini starter.
  #535
Old 10-16-2016, 08:54 PM
71 T/A 71 T/A is offline
I lived in Toronto many years ago. Maybe it's time to go back. LOL!
  #536
Old 10-16-2016, 08:55 PM
cnc's Avatar
cnc cnc is offline
Originally Posted by wheelspin View Post
Nicely done, Chris!
Thanks Les......hopefully out one more time with drag radials , Ernie and Andy....the Pontiac trio.....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #537
Old 10-16-2016, 08:58 PM
thought the t2 was the better intake? i run a q-jet so need the spread bore flange. i have one of the cheap repro single plane intakes, hurricane i think. i might play with that & steal its water x-over. i have a formula hood on a 72 firebird so am limited to only a couple intakes that will fit under the hood...
  #538
Old 10-16-2016, 09:21 PM
Pretty well..it does discharge slightly so its nice to keep it on a battery tender or disconnect it.No real issues..when I first installed the battery it was turning an old starter that needed a bit of juice to crank the engine..did fine with it...with the RobbMC mini..it just whips it over hot or cold..
  #539
Old 10-16-2016, 09:27 PM
I believe I can get it down a bit more just with carb,timing and very minor suspension and chassis work...I'd like to get out again this year before any major changes are made this winter.
  #540
Old 10-16-2016, 09:42 PM
grandville455's Avatar
Holy ****!! Way to go man!!
Darby
M/T 275/60 ET SS Drag Radial
