Old 02-20-2017, 05:40 PM
grandam1979 grandam1979 is online now
That happen to my engine on the dyno ran the first pull to 6000 with 80+ psi all good. Let it sit for a couple minutes then when we start up 10psi no better so im thinking the new motor is toast. The guy running the dyno tells me he has seen this before that he thinks something is stuck in bypass. So we remove distributor run pump clockwise with drill reinstall distributor and psi was good 25 at idle and 80+ 0n all the other pulls. Motor has been in car for 5 years now and has never done it again. You could remove the filter housing from block and just look at it clean if needed that way you would not need to remove distributor. It wont be hard to remove unless you have A/C
Old 02-20-2017, 05:55 PM
lrosen's Avatar
lrosen lrosen is offline
Thanks, I will try that. I had the filter adapter off the block last season to install a new gasket as the old one leaked.
Guess I should order another gasket too.
1967 Firebird 326 H.O. Conv., M3 floor shift, 3.36:1, Montreaux Blue/Parchment, Dual factory traction bars
2005 IBM GTO M6 - One of 347
1984 Yamaha FJ1100
