Old 04-01-2017, 03:16 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Originally Posted by GTOGEORGE View Post
With my 330 e heads and gas I ran 8.70's (in the heat).....last year (in the heat) I ran 8 teens with HP's.
GTO George
Same boost numbers or same pulleys, same cam ?
Old 04-01-2017, 05:17 PM
mgarblik mgarblik is offline
From every objective viewpoint, the e-heads shouldn't be worth a damn, yet they do perform amazingly well when lots and lots of time and effort is put into them. Unfortunately, what you are left with is a flimsy and delicate head, once you port the heck out of them, move the water holes, grind and fill, put good seats in them, open the push-rod area. It's just one heck of a lot of work. But for many years, it is all we had other than Wenzlers. The Tigers start out so much better it isn't even a comparison. But many serious players, like the Crow, Rodney Butler and many, many others had already invested thousands of dollars and hundreds of hours on the E-heads and didn't want to jump ship to another head. I understand this. The cost can be huge to make the change because it's not just the heads. Lifters, pushrods, rocker gear, valves, springs all have to be changed. If you use good parts it can easily cost 15K to change all that stuff if you include the cost of the new heads, porting, flow development, different intake. It's allot more than just the head castings. Edelbrock had a HUGE advantage by being the FIRST and ONLY choice for over a decade. In my opinion, this is why the Pro-Port head was a failure. A much better head, but way too late coming out and lots and lots of good choices now. Nobody left in the hobby with money and interest in really developing them.
Old 04-01-2017, 07:56 PM
v869tr6's Avatar
This thread is about the Crow, the Crow is a TURBO car that runs 40+ psi of boost, some turbo cars are starting to run 80 psi, so no real port work needed. Good valves and springs, top hat washers and tubes in E heads to keep the studs tight and a good size cam. That and a bottom end that stays together will tear up most cars, LOL
Old 04-01-2017, 08:42 PM
X2. Say you have the typical 330-340 cfm E- head out there available from a lot of people.
13.5 psi of boost will make 850 hp on a very basic 455 type engine. Luhn Performance proved that deal.
Many Years ago there was a guy named Doug Hess who ran 8.40s with his heavy Camero with a 350 cid engine. Article by Woody Hatten in Super Stock magazine.
So Doug put a single dominator on a new car (Monza body - same engine) and TURNED UP THE BOOST and ran well into the high 7s. HE WAS RUNNING TWIN TURBOS SO THAT WAS EASY TO DO. many years later, as you said v869tr6, that still is the way to make big hp, and not so much on the cid and head flow side of the deal. Only reason why you need the head flow is if the class restricts boost and engine displacement.
Old 04-02-2017, 12:31 AM
GTOGEORGE's Avatar
I (KRE) made almost 800 hp with a 455 and a 250 B & M street charger roots blower and ONLY 8 lbs of boost with 320 e heads! Big Deal!
GTO George
Old 04-02-2017, 02:19 AM
You drunk george?
Old 04-02-2017, 08:07 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Originally Posted by chiefbigb View Post
You drunk george?
No doubt!
[email protected]. 3460#s
Old 04-02-2017, 11:19 AM
GTOGEORGE's Avatar
You drunk george?
Explain.....I'm old! nothing I said was wrong.
GTO George
Old 04-01-2017, 09:01 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Chiefs heads are very basic...no moved pushrods, have standard rockers, standard port...not much money in that deal and they seem to have held up well...
1969 GTO, 5.77 @ 121 1/8th mile 3450 lbs...535 with Junk dinosaur Eheads
Faster on nitrous…
