#261
Old 07-22-2016, 07:56 PM
Held for Ransom's Avatar
I wonder how big the Kinko's (or Office Max) scanners are. Mine is only 12x17.
  #262
Old 07-22-2016, 08:47 PM
TA455HO's Avatar
TA455HO TA455HO is offline
I called one of the local FedEx/Kinkos centers and they said they had a copier machine that could do it. $3.99 a square foot, so about $8 a color copy of this size. I'll have to call and ask again how much if just black and white, although it would lose the patina'ed look.
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
  #263
Old 07-22-2016, 10:36 PM
unruhjonny's Avatar
Originally Posted by TA455HO View Post
Hi Chuck. I do believe the same/similar door handles were used across a wide range of cars (Corvette, Chevelle, Camaro, Firebird, GTO, Nova, etc.) but the number 20322800 is a newer part number.
Here's some on eBay that are for sale. See, I'm glad I only paid about $26 for the pair of door handles I have. This is crazy!
http://www.ebay.com/itm/NOS-GM-Clear...JXhsRC&vxp=mtr
At least it is free shipping....
EGADS!!!
That really makes me content with nice/used - sheesh.
1970 Formula 400
  #264
Old 07-23-2016, 08:24 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Default Window crank
Thanks for the link!! Not sure how I missed the original discussion. I too had thought my knobs had yellowed over the years and were originally clear. When you look at the prices for NOS, mine work just fine for now. I'll look into the different sources suggested. As always I appreciate the great feedback from the PY'ers!
Originally Posted by Norwood View Post
I thought this thread spelled it out pretty well. http://forums.maxperformanceinc.com/...t=Window+crank
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
  #265
Old 07-23-2016, 06:19 PM
TA455HO's Avatar
Not sure if one or either of these is correct. AC-FC-91 or AC-FC2? The one has a price sticker on it for $1.99.
FC91
or
850843 1.758 All V/8 exc. X/307 CAP (type FC-2) 1 1968 1975 1-36
I have another of these that has a shorter handle and no holes in the measuring end that I will run 99.9% of the time after reading about NJSteve's story.
9793342 1.516 All V/8 exc. A.C. or 307 ROD 1 1971 1974 1-30
I believe this is the original air cleaner to my car. Clips for the hoses that run to the ThermAC switch look good.
6486686 3.402 All F/Trans. Am CLEANER 1 1971 1971 3-16
9779008 0.303 All V/8 exc. 307 SPRING (inner) 16 1971 1972 0-21
9779009 0.303 All V-8 exc. 307 SPRING (outer) 16 1971 1972 0-21
The old throttle cable looks excellent. I've never found one of these NOS yet.
482736 3.430 All F/4 B.C CABLE 1 1971 1971 3-29
These original heater cables also look excellent.
478441 8.849 All F exc. A.C CABLE, heater air inlet & defroster 1 1970 1972 8-36
482895 8.849 All F exc. A.C CABLE, temp. control 1 1971 1975 8-36
  #266
Old 07-31-2016, 03:43 PM
TA455HO's Avatar
Once again thanks to Bentwheel for the info on this one.
6484242 3.415 All SENSOR PKG., air cleaner or air inlet vac 1 1968 1972 3-24
Here's the supercedes of a few more part numbers and how they trace back. Obviously more 1970 only parts that I'm not sure are all mentioned in that thread.
The pick tag of the left hand one says the number that these supercedes is 9849686, which leads to the older part 9808480.
9808480 12.242 23 LOCK 1 1970 1970 12-7
9849686 12.242 All F, B & G LOCK (manual) 1 1971 1972 12-7
9849686 12.242 All LOCK, manual 1 1973 1975 12-7
20291279 12.242 A, B, F, G (EXC S/W) LOCK, COMPT LID 1 1976 1976 12-7
9806078 10.783 All F REGULATOR (man.) (w/std. trim) RH 1970 1970 10-1
9806079 10.783 All F REGULATOR (man.) (w/std. trim) LH 1970 1970 10-1
9833310 10.783 All F REGULATOR (man.) (w/custom trim) RH 1970 1970 10-1
9833311 10.783 All F REGULATOR (man.) (w/custom trim) LH 1970 1970 10-1
1657380 10.783 All F REGULATOR (repl. 9833310) RH 1970 1975 10-1
1657381 10.783 All F REGULATOR LH 1970 1975 10-1
20041528 10.783 F CP REGULATOR, F/D WDO MANUAL RH 1976 1981 10-8
20041529 10.783 F CP REGULATOR, F/D WDO MANUAL LH 1976 1981 10-8
Of course, I only have the LH one.
7805822 6.521 All ADAPTER, strg. lower brg 1 1969 1975 6-17
378137 6.022 All exc. H NUT (3/4"-20) 2 1935 1975 6-1
3985839 6.321 All exc. H WASHER, spindle 2 1962 1975 6-8
5667628 6.861 All exc. H/S.S NUT (7/8"-14) 1 1955 1975 6-38
5697702 - I'm not positive this is correct. It seems to compare favorably to my original so I can't see why it won't work.
7828871 6.525 ALL W/P.S. (EXC H) ......... COUPLING, W/FLG 1 1976 1976 6-26
6480215 4.342 F (M21) .................... CABLE, SPEEDO FLEX W/CASING (UPB) MM), 4SP 1 1976 1976 4-19
These last two again seem to compare to what I believe to be my originals so they should be fine.
  #267
Old 08-15-2016, 04:01 PM
TA455HO's Avatar
I'm really starting to get things organized. I've been going through lots of hardware fasteners and figuring them all out. Well, most of them anyway.
7450630 6.234 All A, F, G, H, X BEARING (LM67048-LM67010) 2 1969 1975 6-7
These are the front wheel seals.
3965092 6.326 All B, F SEAL (1 61/64" I.D. x 2 9/16" O.D.) 2 1971 1972 6-8
3966202 5.002 All B, F GASKET (to splash shield) 2 1971 1972 5-2
5474406 4.665 All D.B SLEEVE, hsg. retainer bolt 4 1971 1975 4-18
1362835 8.890 All (2.447) SWITCH 1 1969 1970 8-43
479767 9.649 All F BEZEL, tun. knob exc. AM & FM stereo or spkr 1 1970 1974 9-39
These are the shim washers for behind the door strikers
4469196 10.571 All WASHER, (5/64" thick) AR 1965 1972 10-5
Glove box arm stop sleeve.
9796336 10.268 All A & F SLEEVE, stop 1 1970 1971 10-5
I do need one more of these if anyone has one to sell or trade.
Front wheel bearing dust grease cap
3984810 6.330 F/6-F/8 ................. CAP 2 1970 1970 6-8
  #268
Old 09-03-2016, 03:54 PM
TA455HO's Avatar
Here's a few more items that are ready for final assembly.
Driveshaft strap bolts. These are the older part number called out in the assembly manual. These have been superceded by part number 14018700.
3887348 5.586 All X, F BOLT, strap to flange (5/16"-24 x 1 5/16") 4 1971 1972 5-32
I could not find a lot of info on these parts. The longer over the door pieces especially. These have been repainted to match the original color. I think they turned out really nicely.
9747793 - RH Garnish Moulding
9747794 - LH Garnish Moulding
  #269
Old 04-04-2017, 01:34 PM
TA455HO's Avatar
I think Mike is outpacing me - OK, I know that he is. But, I am *trying* to keep up.
One good thing about western Washington state is that nothing tends to yellow or fade much.....*chuckle*
Here's the fuel and volts gauge set - without the lens installed yet. The faces just needed a little cleaning and they are good as new - I think anyway.
Chad
  #270
Old 04-04-2017, 02:58 PM
unruhjonny's Avatar
are those replacement gauges?
I'm pretty sure the originals had circular gauge faces - not that you would be able to tell once installed.
1970 Formula 400
  #271
Old 04-04-2017, 03:09 PM
TA455HO's Avatar
Those are the originals from my car. It's all an optical illusion they create...lol.
The round look just comes from the black plastic housing cover just behind the lens. And, of course, the round holes in the dash bezel.
Now, here's the challenge. Compare Mike's fuel/volt gauges that he had redone to mine that are stock. Can you tell what is different? Shhhh.....don't tell Mike.....
Chad
  #272
Old 04-04-2017, 03:14 PM
unruhjonny's Avatar
huh, shows just how longs it's been since i opened up gauge clusters!
1970 Formula 400
  #273
Old 04-04-2017, 03:43 PM
You're both outpacing me. I guess I need to bring my thread up to date on all the work I'm doing.
  #274
Old 04-04-2017, 04:18 PM
TA455HO's Avatar
If you've been doing a bunch of work you are likely outpacing me....
Here's a turn signal switch I picked up a while back.
1997938 2.895 All ...................... SWITCH (exc. cornering lamps) 1 1969 1971 2-77
I still need to go thru my steering column and freshen it up.
Chad
  #275
Old 04-04-2017, 04:21 PM
Judge273's Avatar
Judge273 Judge273 is offline
Chad
Needles are different? The script is thinner? At least they spell fuel right...
Mike/Illinois
  #276
Old 04-04-2017, 04:23 PM
TA455HO's Avatar
Shhh......don't tell Mike......
D'oh! You caught me....
  #277
Old 04-05-2017, 07:23 AM
Judge273's Avatar
Have you been assembling any of those parts on your car? Amazing how many little unique pieces are on these TAs!
Mike/Illinois
  #278
Old 04-05-2017, 10:22 AM
TA455HO's Avatar
I hung the doors....meaning they are free hanging. But, I haven't adjusted them to the opening yet. I was thinking about putting the glass in and a couple of other pieces like the latch to give the door a weight closer to reality so I don't have to compensate or readjust it later once I install the glass.
Anyone have any thoughts on door adjustments and what worked well for them? I know I need to align the back edge with the quarter panel and the lower edge with the rocker panel. Any other concerns to consider?
Thanks,
Chad
  #279
Old 04-05-2017, 11:21 AM
Judge273's Avatar
Looks great.
You have 2 sheens of black on dash metal /top of firewall?
Looks flat to semi? Or is the inside blue?
More detail pix please!
Mike/Illinois
  #280
Old 04-05-2017, 11:34 AM
TA455HO's Avatar
My interior is blue in this case. If you scroll up to post #268 you can see the blue on the garnish molding for the "A" pillar and the overhead pieces that help retain the headliner.
If you see anything that looks off in what I post please feel free to speak up. I only do the same to try to help others - just ask Mr. BentWheel. I've shared one of my spreadsheets with him and realized I may be a bit OCD. But, I think he liked it.
Chad
