#621
Looking good TA Man! Great thread with lots of good info, I'll be on the edge of my seat waiting to see what the new combo evolves into. In the meantime I'm saving my pennies for a 455 LOL.
Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR 236/242D .572/.594L, RA manifolds, 11.53@114, 1.55/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, Howard HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
#622
What brand main caps?
#623
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 Last edited by ta man; 02-03-2017 at 12:37 AM. |
#624
Thanks I have a plan for this year,but that usually changes with a late summer upgrade or too. I know with this new bottom end it can handle anything I can throw at it.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
#625
Update,Engine swap under way.Engine was pulled two weeks ago,heads and intake are at SD,rockers are at Harland Sharp for a rebuild.
#626
Do tell about the surgery Dave is doing to the heads.
#627
Not sure on exact details,more head flow,milled for compression target of 11 to 1.Intake being portmatched to the new head port opening.An honest 600hp is the goal with the same street manners,91 octane,900rpm idle and run in the 10's in the heat.
#628
Update Shortblock painted and waiting on topend parts and camshaft..New Romac balancer and ATI flexplate should be here today.I'm confirming TDC on the balancer once it arrives.Purists may notice the noncorrect GM blue..its my lucky shortblock color and easy to buy for touch-ups .Sorry Mike (Potent Pontiac) had to spray it blue instead of black.
#629
Hope that paint is able to withstand 10 second passes!
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
#631
Hmm ya its meant for Chevy's may slow it down!
#632
I'm not sure.early fall Dave B..Suggested trying a different cam with the reworkting of the heads..said it would suit the car.I said sure..So it may be but I didn't get into specifics..he did say over 600hp..that got my attention.
#633
I use that same color for most of mine also.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#634
My guess is the OF 2.
#635
#636
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
#637
#638
Ta_man, have you been running 1.65's on the intake and exhaust? Theres been talk on this site the with good flowing heads, 1.65 may be too much on the exhaust side especially with a split pattern cam(like OF) . Something about over scavenging? May possibility pick up with 1.5's on the exhaust?
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ![]() ([_|_] ##\|/##[_|_]) |
#639
What are specs on OF2?
#640
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 Last edited by ta man; 05-11-2017 at 01:54 PM. |
