Old 02-02-2017, 03:07 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Looking good TA Man! Great thread with lots of good info, I'll be on the edge of my seat waiting to see what the new combo evolves into. In the meantime I'm saving my pennies for a 455 LOL.
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
  #622
Old 02-02-2017, 08:07 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Originally Posted by ta man View Post
Just realized I never posted these pictures.Spring is approaching, soon time to start wrenching.No time bomb shortblock anymore.
What brand main caps?
  #623
Old 02-03-2017, 12:20 AM
ta man ta man is offline
Program Engineering .
  #624
Old 02-03-2017, 05:11 PM
Thanks I have a plan for this year,but that usually changes with a late summer upgrade or too. I know with this new bottom end it can handle anything I can throw at it.
  #625
Old 03-02-2017, 02:47 AM
Update,Engine swap under way.Engine was pulled two weeks ago,heads and intake are at SD,rockers are at Harland Sharp for a rebuild.
Name:	engine swap 4 .jpg
  #626
Old 03-02-2017, 09:49 AM
ponjohn's Avatar
Do tell about the surgery Dave is doing to the heads.
  #627
Old 03-02-2017, 03:34 PM
Not sure on exact details,more head flow,milled for compression target of 11 to 1.Intake being portmatched to the new head port opening.An honest 600hp is the goal with the same street manners,91 octane,900rpm idle and run in the 10's in the heat.
  #628
Old 04-06-2017, 03:01 PM
Update Shortblock painted and waiting on topend parts and camshaft..New Romac balancer and ATI flexplate should be here today.I'm confirming TDC on the balancer once it arrives.Purists may notice the noncorrect GM blue..its my lucky shortblock color and easy to buy for touch-ups .Sorry Mike (Potent Pontiac) had to spray it blue instead of black.
  #629
Old 04-06-2017, 03:15 PM
ponjohn's Avatar
OF2?
  #630
Old 04-06-2017, 03:49 PM
77 TRASHCAN's Avatar
Hope that paint is able to withstand 10 second passes!
Shut it off
Shut it off
  #631
Old 04-06-2017, 03:59 PM
Hmm ya its meant for Chevy's may slow it down!
  #632
Old 04-06-2017, 04:03 PM
OF2?
I'm not sure.early fall Dave B..Suggested trying a different cam with the reworkting of the heads..said it would suit the car.I said sure..So it may be but I didn't get into specifics..he did say over 600hp..that got my attention.
  #633
Old 04-06-2017, 04:21 PM
I use that same color for most of mine also.
  #634
Old 04-06-2017, 08:08 PM
ponjohn's Avatar
My guess is the OF 2.
  #635
Old 05-11-2017, 05:35 AM
Good guess!
  #636
Old 05-11-2017, 07:23 AM
grandville455's Avatar
Good guess!
Secret Squirrel stuff
Darby
M/T 275/60 ET SS Drag Radial
  #637
Old 05-11-2017, 07:38 AM
ponjohn's Avatar
Good guess!
HAHA...Like Madonna and Prince...OF2.
  #638
Old 05-11-2017, 09:22 AM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
Ta_man, have you been running 1.65's on the intake and exhaust? Theres been talk on this site the with good flowing heads, 1.65 may be too much on the exhaust side especially with a split pattern cam(like OF) . Something about over scavenging? May possibility pick up with 1.5's on the exhaust?
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
  #639
Old 05-11-2017, 11:51 AM
71 T/A 71 T/A is offline
What are specs on OF2?
  #640
Old 05-11-2017, 01:47 PM
It may be possible..but I'm pretty sure Dave has done enough dyno testing.I trust his judgement when he is the one porting and setting up the heads and supplying the cam.
