Old 06-27-2017, 11:47 AM
Bonneville66 Bonneville66 is offline
Default 66 Bonneville Vacuum Trunk Release Canister Location
Hi,
I am restoring a 66 Bonneville convertible. It originally had a vacuum trunk release, and I have a NOS kit that I am installing. However, the instructions don't say where the vacuum canister is supposed to be installed. Does any one have an idea? Thank you!
And if your wondering, that paint is Iris Mist, a 65 color. This was an early build car with custom paint request!
Old 06-27-2017, 07:11 PM
Heybuck's Avatar
Heybuck Heybuck is offline
I have a '66 Grand Prix with the vacuum trunk release. It also has ATC A/C. This might affect things???
My car has TWO Vacuum tank canisters. One larger unit is located on the top of the left hand side (Your drivers side), inner fender. This unit appears to be associated with the ATC A/C.
There is another, smaller tank located up above the glove box under the dash top. From memory, it is about the same size as yours seem to be.
HOWEVER, I need to stress that I have never really followed through how all the vacuum lines are interconnected. I have vague memories from when I have been under there that the smaller tank is connected via a "T" piece into main vacuum line feeding the ATC controls. That might be a bit wrong so please don't take that as gospel.
Ian
To laugh at men of sense is the privilege of fools.
Old 06-28-2017, 11:04 AM
Thank you! I was going through the forums looking for an answer, and found a thread on the vacuum canisters on a 66 2+2. That car had two canisters under the hood, the large one and one that looked like my canister. I agree, I think the large one is for the ATC. Here is the pic for the second canister in the 2+2, it had it on the inner fender. Is this for the trunk release or the vacuum door lock option?
Any help appreciated!
Old 06-28-2017, 03:37 PM
Stuart's Avatar
Stuart Stuart is offline
It would make sense that this one is for the trunk release - I assume the pushbutton goes inside the glove box? That's where it was in my old '71 Catalina.
Old 06-28-2017, 11:57 PM
Heybuck's Avatar
Yes Stuart, the push button is inside the glove box, closest to the driver and just under the hole for the light.
The vacuum tank (on my car) is directly above it. I only have ONE vacuum tank under the hood.
Old 06-29-2017, 11:23 PM
Yes that is correct, the button is in the glove box. I guess over the glove box is where it will go! Thanks for the help.
Old 07-03-2017, 10:10 PM
barrierblue66's Avatar
barrierblue66 barrierblue66 is offline
Great thread! I bought the same option for my 66 GP. Good info when I get around to install it.
Sent from my XT1254 using Tapatalk
'63 Catalina Safari, Silverleaf Green / Cameo Ivory, nice options, 4 speed
'66 Grand Prix, Marina Turquoise, 421 HO, many options, 4 speed
My Garage
Tarheel Tigers Pontiac Club of Raleigh, NC
Old 07-04-2017, 09:53 AM
Jeff Hamlin's Avatar
Thumbs up
Nice Score!
Clearly the seller did not know what they had, as that is not for the A-Body models.
I just hope you didn't pay A-Body prices for it
The '66 A-Body unit is VHTF and can be well over priced if you do locate one
I recently installed the '66 (A-Body) Vacuum actuated deck lid release in my Lemans which uses no reservoir can,
very simplistic system. The '67 A-Body was Electric.
FWIW here's the info on the install for '66 Tempest/GTO
http://forums.maxperformanceinc.com/...d.php?t=801209
Neat stuff, Love the old Pontiac gadgets
Old 07-04-2017, 11:27 AM
Hey Jeff, yes I followed your thread on the install. I'll be getting to mine later in the year. Should be interesting as my vacuum is low at idle (10-12) I thinkbecause of the RAIII cam. But I'll mock it all up outside the car to see if it will work. Maybe it will be done by the Henderson show, but you probably wont be there 2 years in a row
Ken
My Garage
