Old 10-08-2017, 12:38 AM
chiphead's Avatar
chiphead chiphead is offline
Default Source for 3" main, 4" stroke forged cranks?
I'm ready to hop off the fence on my build and buy a crank. Who has the best price and quality on a Scat or similar forged 3" main, 4" stroke crank for a 400 block?
Old 10-08-2017, 02:05 AM
ponyakr's Avatar
ponyakr ponyakr is offline
The Spotts' site shows forged cranks for $649 + shipping. If that price is current, it's the best I know of. Have no idea if price is current or if he has one in stock.
http://www.spottsperformance.com/cranks.htm
RPM shows one for $720.
http://www.racingpartsmaximum.com/fo...sae4340-4.html
KRE shows 'em for $750 + shipping. You may have to call around to find one in stock.
http://www.krepower.com/Pontiac%20Cr...and%20Rods.htm
Sandoval's price is $795 + shipping.
http://www.sandovalperformance.com/_...2-stroke-crank
The Butler price is $800 + shipping.
http://butlerperformance.com/i-24453...tegory:1234870
Old 10-09-2017, 01:56 PM
Formula8's Avatar
Formula8 Formula8 is offline
These were on back order several months ago. I ordered one from Paul Knippen's Muscle Motors and ended up with two cranks as our prior order came in. I think Paul kept the second one that came in so you might want to drop Paul a line at (630) 400-4441 as he may still have it in stock. If not, he can get you one at a fair price.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 10-09-2017, 03:50 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Are these a 2.20 crank pin?
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 10-09-2017, 08:47 PM
chiphead's Avatar
Yes, these use the BBC RJ.
KRE is out of the standard weight scat forging. I sent Paul a PM on FB asking what he had in stock.
What do you guys think of the RPM forgings?
Old 10-09-2017, 09:09 PM
I would definitely have it magnafluxed and stroke/journals checked before using it. I've heard good and bad about their forgings. Also, have the hardness confirmed. If the crank grinder you take it to has no idea what I'm talking about, RUN! PM me and I send you the phone number of crank grinder who does.
Dr. Thomas Sowell
Old 10-11-2017, 01:22 AM
Formula8's Avatar
The dimensions on my Scat forging were near flawless.
Old 10-11-2017, 10:41 PM
Aren’t most of the overseas pieces forged at the same places?
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 10-12-2017, 12:22 AM
Dragncar Dragncar is offline
Has anyone ran the cast 4" stroke cranks hard and had trouble ? Bet with that short of stroke they are pretty tough. The cast 400 cranks hold up very well.
Old 10-12-2017, 07:36 AM
That is like saying all steel is produced in Detroit. (Not likely).
China is such a big market for vehicles and industry there are MANY MANY Forging houses for steel products. One of the largest Turbo manufacturers has a new massive Plant in China and is using China Aluminum, China Steel, and China Workers to put the stuff together.
So to assume that a few places are making all of the parts might be a stretch.
There are 'layers" of manufacturing: Jim/Bob's Forging House, ABC Forging House, General Motors Forging House, etc. GM sells more vehicles in China than the USA/ Mexico and possibly Canada sales combined in a year. A Lot of Buicks.
SCAT has a high enough volume that they can use a quality Forging House. And possibly they still do all of the machining of their cranks still in the USA. Being "spot on" with a SCAT crank does not surprise me.
Old 10-12-2017, 09:03 AM
Bnick166's Avatar
Bnick166 Bnick166 is offline
If one asks a crank company where the steel is sourced from, most...if not all will tell you it is proprietary info. I was told this from Ohio Cranks when I purchased my billet crank. Doesn't hurt to do your homework. Ask around and see if you can gleen any info on the base steel and it's origins. I'd think if any crank manufacturers are using "High Grade" American steel...they'd display it and wear it like a crown. One can source "dirty steel" from any country....including the USA.
Old 10-12-2017, 10:45 AM
Kind of more of a question vs. an assumption. I ask because I really don't know.
You say SCAT uses a quality forging house. I gather SCAT has the ability to Xray, if you will or do whatever else is needed to determine if the forgings are up to their standards?
Again I'm asking as I know very little about this.
Is SCAT the only one doing this?
I have a SCAT 4.25 forging from Butler's and a Star Galaxy 4.500 forging from FrankG. I don't really care which one I use, but I prefer the better of the 2.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 10-12-2017, 01:20 PM
Have no knowledge of the Star Galaxy Cranks. believe Butler and Frank were involved in some deal with them.
The Scat stuff first sold by Wade/Mark (BOP) and Bob/Frank were good cranks for the money. Metal was pretty clean. Clean metal means less chance of a imperfection causing a crank in the crank and it failing. Have no knowledge on the new Scat Cranks, only the fist run stuff which I bought 3 of them.
To
Old 10-12-2017, 02:55 PM
Molnar uses his own source of Chinese steel. Scat likely has their own source. StarGalaxy Cranks initially tested good.
Old 10-12-2017, 03:05 PM
I decided that a fully counterweighted billit of high quality us steel is worth it.
Old 10-12-2017, 06:42 PM
gata79 gata79 is offline
My star galaxy had to be replaced after one season. Lots of cracks.
Old 10-12-2017, 06:52 PM
Wonder if one could source an unmachined forged 3" main 4" stroke in a shipment of SCAT's???
Would like to duplicate a 4.06 stroke crank, but with 3" main, need 2.25 rod journals in order to offset grind.
Old 10-12-2017, 07:10 PM
Be worth a call OPH!
Old 10-13-2017, 06:10 AM
Money Pit's Avatar
Money Pit Money Pit is offline
My 4.250 Star Galaxy I bought from Butler in 07 is still perfect. And it see some decent power in a heavy car.
Old 10-13-2017, 04:17 PM
You could just buy a Scat 3"x4" crank with the BBC rod journals and send it to Crankshaft Specialists. I talked to them about stroking up a 4" crank. They just let it sit in a chrome bath all weekend and build up the journal. Then they can offset grind it to whatever spec the thickness of the chrome allows.
Yours would be a piece of cake, not that expensive either.
