I need to replace the filler tube o-ring on the th350 in the Bird. Is the fluid level below that point in the case or will I loose fluid out the filler tube hole? Thanks.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far... |
Seems like fluid level is above the o-ring with the engine not running.
I have changed them by jacking up passenger side only without making a mess. Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
Mine had leaked down so that no more would run out. If I'd kept the car, I'd have swapped the tube for a FitzAll stick & tube, with the top hat type seal. My tranny guy told me about 'em. Says he has sold a lot of 'em. Says top hat seal works MUCH better than the single O-ring.
Or, if you wanna keep your stock tube, you can cut off the end & attach one of the top hat seal type repair ends. I think Cliff has mentioned using these. These parts are sold on Ebay, Amazon and probably lots of trans shops. http://www.fitzall.com/filler_tubes.php https://www.amazon.com/Universal-Aut.../dp/B00B40MPVM http://www.ebay.com/itm/TH350-TH350C...ZRlSCr&vxp=mtr http://www.ebay.com/itm/Filler-Tube-...JWp9SE&vxp=mtr http://www.ebay.com/itm/Dipstick-Fil...-/300803616743 Last edited by ponyakr; 10-17-2017 at 05:18 PM. |
Thanks for the tips; may look into the Fitzall solution.
Do you know how it’s attached? I didn’t see where the descriptions mention this. Welding, brazing or just a slip fit with sealant?
-- Kevin 1971 Trans Am, White/Blue 455 YC Block with Edelbrock Performer RPM Aluminum Heads, 10-10.5 estimated CR, E-Performer Plus cam (soon to be 041 + Rhoads), Comp Cams 1.65:1 roller tip rockers, E-Performer Aluminum Intake (soon to be topped by a FiTech EFI), TRW forged pistons, Hedman Husler Headers, 3" dual exhaust with Flow Master mufflers. |
For info, the factory tube in my 69 Firebird's TH350 is the "top hat" style seal.....first time I'd seen one, my auto trans guy said they are a much better seal than the o ring.
Regards, Leigh Pontiacs I’ve owned…. 1960 Laurentian 283 1963 Laurentian 283 1976 Trans Am 400 1977 Trans Am 400 1951 Chieftain Flat head 6 1967 Firebird 400 convertible 1967 Firebird 400 coupe 1979 Trans Am 403 1971 Formula 455 (clone) 1969 Firebird 350 1968 Firebird 428 manual. Sydney, Australia |
I've seen a lot of factory tubes from the late 60's & early '70's. And I never even heard of a top hat seal, until recently, much less saw one on an original '69 tube. So, are you saying that you have a '69 tube that came from the Pontiac factory with a top hat type seal ? Or is it a factory tube which has had the end changed over to the top hat style.
I'll do a search & see if I can find that thread. Here's 2 of 'em. http://forums.maxperformanceinc.com/...light=dipstick http://forums.maxperformanceinc.com/...55#post5689355 Last edited by ponyakr; 10-18-2017 at 10:18 AM. |
Thanks ponakr, I already have some Marine Tex so I think I'll go with the FitzAll repair part and give it a shot.
