Ross 4.375"
GRP 6.735"
I'm sitting here thinking bout this new build and lightening it up from what i had, I'm surprised how light some of these are, compared to mine which i thought ran pretty damn good!
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
You're using a heavy rod and ring pack.
Crower Lightweight 4.125 billet crank
Crower Midweight billet 6.8 rods JE 4.310 pistons 2303.4 1/2 = 1151.7 .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
If he were talking about a Carrillo 366 cid engine rod or 303 cid engine rod they would be 7.080" inches long John M.
He did not say 366 or 303 engine so assume your rod length question is valid (he had a typo error). Tom V.
Must be why my car is a turd, got heavy rods in, and a crank that weighs a ton
Yeap, Going to be changing that Paul!
Yea, turd , right lol
455 + .030. Eagle rods, Sealed power forged pistons. factory crank. neutral balance
My rods weigh around 850g, crank weighs a ton, don't worry to much about weight. Use the K.I.S.S method! Imo there is next to nothing in reducing crank, rod, piston weights as far as performance goes.
Have u tried lighter stuff Brian? To me anything that helps lighten the assembly the easier to turn n less wear n stress?
Generally that's how it starts out, the lighter the better. As you make more power you need heavier parts to stand up to the additional load. Next you have to pay the big bucks for stronger lighter parts, like ones made out of titanium.
Ive had lighter rods and crank, no performance difference, in another engine we went from alum rods to steel, no performance difference. The lighter rotating assembly seem to rev quicker in neutral but that's it.
When you switched to the aluminum rods and saw no difference, were the counterweights turned down or drilled?
#38
FWIW Chris U on yellowbullet has a 9000+rpm record setting bbc with 800+g rods |
#39
When switching from a steel rod to aluminum rods you want to turn the counterweights down rather than drilling holes when balancing the crankshaft. Any gain you might of seen from the lighter rods may have been absorbed in windage losses due to the holes machined to balance the crank. You'll also benefit from the shorter counterweight.
#40
Besides that how does lighter rods increase performance? |
