Old 11-18-2017, 09:32 PM
TB1's Avatar
TB1 TB1 is offline
Default Looking for 8.2 open carrier and 3.23 or 3.55 gears or just carrier for 3.08
Hello
I have a 65 Lemans and had purchased a used Powertrax no slip locker to install and come to find out it appears that at some point a GM 8.2 carrier was installed in the car. The Pontiac carrier uses a .800" cross pin and the GM .7325" pin which is what my car has. Ideally I'm looking for a open carrier that will work with the stock 3.08 gears but I'd be interested in 3.23 3.36 ,3.55 car has a M20 and will be getting a 455 in the next year or so currently a 6 cylinder. Im located in Canada so the killer may end up being the shipping but interested to see whats available
thanks
Trevor
Old 11-18-2017, 11:08 PM
ponyakr's Avatar
ponyakr ponyakr is offline
"...Ideally I'm looking for a open carrier that will work with the stock 3.08 gears but I'd be interested in 3.23 3.36 ,3.55 car has a M20 and will be getting a 455 in the next year or so..."
Sounds like you'll be needing a posi unit. If you need an 8.2 BOP posi carrier that will work with 3.08 gears, Auburn makes 'em. I'm not clear whether you have a Chevy 8.2 or a BOP 8.2. They are different.
http://www.ronsmachiningservice.net/...-3-23-5420114/
If you have a BOP rear, it might be a good idea to go with at least 3.36 gears. New ones are still sold.
https://www.ebay.com/itm/Yukon-Gear-...paAd15&vxp=mtr
http://www.ronsmachiningservice.net/...posi-gear-pkg/
The BOP 8.2 will usually hold up OK, with hard street tires. But, I broke a pinion, in a 455 bracket car, with slicks. Switched to 12-bolts & never had any more rear end problems.
So, if you ever put sticky tires on your car, behind a 455/4-speed, you might break something. Might wanna consider a rear end upgrade, instead of spending money on an 8.2. Just a thought.
Old 11-18-2017, 11:17 PM
TB1's Avatar
TB1 TB1 is offline
I have a 1965 Pontiac Housing but I'm pretty sure that at some point a GM 8.2 carrier was installed because the Powertrax locker I went to install the other day worked great until the cross pin would not fit, tech support told me the Pontiac 8.2 used the .800" cross pin and the current one in my car is smaller at .7235" which they told me was GM.? if that makes sense wanted to use to locker I had already bought but might be better off getting a new posi carrier installed and sell the powertrax
Old 11-19-2017, 12:16 AM
ponyakr's Avatar
I've never heard of putting a Chevy 8.2 carrier into an 8.2 BOP housing. So, you may need to get someone to help you make a positive ID on exactly what you have, before spending any more money on it.
Old 11-19-2017, 01:58 PM
TB1's Avatar
TB1 TB1 is offline
I pulled the carrier from the car today. Pinion is 27 spline. Ring gear is mounted with 10 3/8” 24 bolts so from what I can tell it’s a Pontiac 8.2?
ID:	468049Click image for larger version
ID:	468050Click image for larger version
ID:	468051Click image for larger version
ID:	468052Click image for larger version
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt
Old 12-16-2017, 03:17 PM
TB1's Avatar
TB1 TB1 is offline
Bringing this back from the dead, still looking for a good used open carrier with 3.23,3.36, 3.55 gears that will fit a 1965 10 bolt rear end that I can use my Powertrax locker with, needs to have a pinion cross shaft diameter of .800". I.m located in Canada dont mind paying shipping as long as it ends up being cheaper than buying brand new
thanks
Trevor
Old 12-17-2017, 11:10 AM
400 Lemans's Avatar
http://forums.maxperformanceinc.com/...r.php?u=136744 PM this guy he will have what you need.
Old 12-17-2017, 05:12 PM
TB1's Avatar
TB1 TB1 is offline
Thanks, I'll give him a try
Old 12-18-2017, 10:16 PM
pontorquer's Avatar
pontorquer pontorquer is offline
I have one from a 1969 Grand Prix 3.23 open, would this work ? Located near Winnipeg MB
Old 01-07-2018, 03:18 PM
newmexguy newmexguy is offline
Default 66 Pontiac rear end
Have access to this in local yard. Black's Auto, dona Ana NM. Decodes to '66 date code, 8.2 in rear end, 3.36 open. PM or more details. Believe this is a true Pontiac rear. Willing to investigate further. Dave S. dona Ana NM 88032
ID:	471889   Click image for larger version
ID:	471890   Click image for larger version
ID:	471891   Click image for larger version
Old 01-07-2018, 11:03 PM
TB1's Avatar
TB1 TB1 is offline
Thank you for the lead, I think I might have found one in Canada which will save a bunch in shipping but if it falls through I will message you about it
thanks
Trevor
Old 01-13-2018, 11:34 AM
TB1's Avatar
TB1 TB1 is offline
Carrier has been found Still would like to get a set of 3.23 gears if anyone has some
