#1381
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
#1382
Panos Little Miss G Racing on Youtube |
#1383
No oil scavenge pump on the turbo drains at this time, though not out question though. The TurboWerx Exa-pump looks like a nice piece.
#1384
#1385
You can see the blue return line on my setup. It has a very slight pitch to it. I got to add a pump to it, because at idle and low speeds it was not draining fast enough, and was smoking like a chimney Hate to see that happening on your setup.
#1387
Looks like you have a 90 degree fitting right under the turbo, that is not helping your "draining fast enough" at all.
Oil and AIR BUBBLES come out of the bottom of the turbo. Large Bubbles and 90 degree turns do not work well, as at idle and low speed you really don't have that much oil flow to the turbo CHRA, (Center Housing Rotating Assy). So the oil pushes past the simple seal on the exhaust side and gets burned. You have an OK downward slope to the line but you need a smooth curved pipe drain coming right off the turbo. A turbo like yours should have threads and also the bolt on flange. Weld a smooth 5/8" id tube bend on a piece of flat stock with a 5/8" id hole in it and bolt that on to the turbo. Get rid of the threaded crap. Tom V.
#1388
Either way, I thought the slope on mine was steeper than Ed's setup, and I was not happy with mine, that is why I brought it up
#1389
Turbo Drains are far more important than many assume. Constant down hill slope, LARGE ID of the tube off the turbo, no screw in fittings as the fitting threads take away from the inside diameter tube size.
#1390
Final assembly/wiring is in progress. Radiators are 7-10 days out. Mandrels for cam cable driven fuel pump and crank driven alternator about another week.
#1391
Looking great Ed.
#1392
Ed's Car is Looking Great!!
#1393
How long till it hits the Dyno?
Chris Collier 1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans "There is no such thing as too much horsepower" |
#1394
No chassis dyno eta at this point.
#1395
#1396
The turbo oil drains are ~2 inches above the full oil level.
#1397
#1398
I can't even afford to look at that stuff lol. Very nice work.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
#1399
Ed Page's 1969 Firebird "RAVEN" is almost done.
#1400
So the clear view oil filter will be covered by the charge tube going into the firewall? Defeats the purpose no?
6.98 @ 199mph 4.53 @ 164mph |
