Old 02-27-2018, 03:01 PM
Rich-Tripower's Avatar
Originally Posted by JC455 View Post
For anyone interested in the Putco Plasma Red LED's:
https://www.summitracing.com/parts/p...-360/overview/
Is that price each?!? I can almost bet you that Sylvania Zevo bulbs would be as bright and only cost you between $15-$25 a pair and come with a lifetime warranty. As well, they are typically available at most well stocked parts stores or you can shop ebay for the best prices.
https://www.ebay.com/itm/Sylvania-Ze...xakfdK&vxp=mtr
Old 02-27-2018, 03:53 PM
JC455 JC455 is offline
That's for a pair.
I never said they were the cheapest, I said they were a great product. The LED's you show are not the same design as what I have. Look at the pictures from Summit vs. your eBay link.
Maybe the Zevo lights are fantastic, I don't know, but I do know- and have shown pictures- that the Putco Plasma Red LED's are amazingly bright... they made my Tempest visible!
John
IG: @crawdaddycustoms
Old 02-27-2018, 09:48 PM
That's for a pair.
That price for a pair at least makes more sense. Not saying they aren't wonderful, but I'm saying the Zevo bulbs are incredible, especially for the price point. The design looks funky but they really work and are so damn bright you can't really look at them head on.
Old 02-27-2018, 09:58 PM
64speed's Avatar
64speed 64speed is offline
Any problems with these working with the stock flasher? Do the blinkers still work? I read that LEDs do strange things
Old 02-27-2018, 11:15 PM
tempest1964's Avatar
I thought this thread was about brake /tail lights, not turn signals.Other threads have addressed turn signals. This upgrade sounds pretty straight forward.
Old 02-28-2018, 02:12 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
According to some of the sites that list led strip lights, (NOT BULB REPLACEMENTS) the turn signal flasher will work properly if the
front turn signal bulbs and park lights are stock type bulb. If the front bulbs are led as well you will need to change the flasher to a Light duty flasher or
a no load flasher, don't use a heavy duty one or you will have issues. Taken from Digitail installation instruction.
64 Lemans hardtop
4spd, buckets
Old 03-02-2018, 10:23 PM
smasse64 smasse64 is offline
Default I used reg Sylvania LED 1157's....
....and they made a 25% brighter difference..i did have to order a nice LED flasher with a ground wire on it which goes into the screw on corner of fuse panel...keeps the blinkers slower and makes a real nice old school clicking sound..little delay on shut off of clicking noise, but i can live with it...and only cost $20 for 4 bulbs...why spend more?
Old 03-02-2018, 10:32 PM
MecGen's Avatar
MecGen MecGen is offline
I realize buy now you have already installed them but how hot do they get inside the lense? I am reluctant to get these in case they melt the lense...
Sent from my SM-T530NU using Tapatalk
Old 03-05-2018, 12:23 AM
Default no issues with heat so far over one...
FULL SUMMER....
Old 03-05-2018, 07:51 AM
The Champ's Avatar
Although brighter, LED's actually emit much less heat than an incandescent.
Incandescent and CFL bulbs get so hot because most of their energy is being released as heat, not light, making them much more ineffeicient. Proprietary tests show 100W incandescent lights burning at 335.4 F, CFL lights burning at 179.2 F and LED bulbs burning at 87.2 F.
Old 03-05-2018, 08:57 AM
MecGen's Avatar
Thats what I always was told as well, but these are "Plasma" so I was unsure if it changed something in the heat department.
Cheers !
Old 03-07-2018, 01:52 PM
Sorry, I didn't see your question previously...
As stated above, they stay way cooler than incandescent bulbs... the Plasma description is more for the intense amount of light they put out.
I'm not going to try to sway any of you, if those 'Zevo' lights work, use them- they are significantly cheaper than the Putco's that I used, and appear to put out a lot of light.
John
Old 03-25-2018, 10:43 PM
Lemans64's Avatar
Tailights pieces should be here tomorrow or tuesday, seems Canada customs wanted to have look at them for 7 days. Will post pictures of pieces when they arrive an post here. Have some spare twilight assemblies so will post how they fit as well. Hopefully Ames will revamp their pictures of parts after.
64 Lemans hardtop
4spd, buckets
Old 03-26-2018, 08:50 PM
Lemans64's Avatar
So here is what you get.
ID:	479167   Click image for larger version
ID:	479168   Click image for larger version
64 Lemans hardtop
4spd, buckets
Old 04-01-2018, 12:42 AM
Lemans64's Avatar
Using a spare set of taillights for mock up.
If the boards were an 1/8 inch narrower they would fit nicely into the lens gasket. The way they sit now, just on top of lens gasket. so I managed to trim gasket a little. Instruction say to put board between gasket and housing but to watch that the circuit on board don't touch housing and short out.
Have glued board to top side of gasket to hold it away from housing further.
ID:	479599   Click image for larger version
ID:	479600   Click image for larger version
ID:	479601   Click image for larger version
ID:	479602   Click image for larger version
64 Lemans hardtop
4spd, buckets
Old 04-01-2018, 12:45 AM
Lemans64's Avatar
more pics, some of the pictures are not straight on as I did not have enough jumper wires and was hold the wires with my other hand, LOL. And almost spilt my beer,
24 rows of 3 led's, so 72 LED'S altogether. on each side. first pic is park lights second is brake, 3-4 same, just with no lens.
ID:	479604   Click image for larger version
ID:	479605   Click image for larger version
ID:	479606   Click image for larger version
64 Lemans hardtop
4spd, buckets
Old 04-02-2018, 12:07 AM
Lemans64's Avatar
Short video of lights in action. Will try and post. No go so will try You Tube
https://www.youtube.com/edit?o=U&video_id=qb5U16ebYIE
64 Lemans hardtop
4spd, buckets
  #38
Old 04-02-2018, 09:37 AM
Dang. You should have warned me. I got to picture 3 and needed my sunglasses. Lol
  #39
Old 04-02-2018, 12:55 PM
LeMans64- Your YouTube link is not working. It is sending me to an upload page.
John
  #40
Old 04-02-2018, 12:58 PM
Fixed it for ya
https://www.youtube.com/watch?v=qb5U16ebYIE
John
