Old 03-11-2018, 11:57 AM
The Champ's Avatar
Originally Posted by Steve C. View Post
"Years ago Fram was a quality filter manufacturer. Now their standard filter (the radioactive-orange cans) is one of the worst out there. These filters are manufactured by Allied Signal, Inc. Please do not buy these filters. By boycotting it, we may be able to cause some change. I have personally had one if these filters fail and actually cause engine damage due to bits of paper and glue floating around in the engine. For some inside dirt on Fram filters, see this email from an Allied Signal production engineer."
Oil filter study: http://www.austincc.edu/wkibbe/oilfilterstudy.htm
That's an excellent article with a whole lot of data in it.
To summarize briefly - it's looking at filters for the Ford 5.0 V8 - an OE part # FL1A.
The OE filter is 4.125" long and 3.25" in diameter. It has 64 cartridge pleats, 400 square inches of element surface area and has a stamped-steel, with bypass valve, end cap.
Compare that to the Fram PH8:
4.125" long, 3" diameter, 34 pleats, 193 square inches of element surface are and has a cardboard end cap with NO bypass valve.
There is no comparison between a Fram PH series filter and a quality oil filter.
