Old 03-22-2018, 05:31 PM
GTOGEORGE's Avatar
Don’t forget he was 100 lbs heavier with the cv heads.....that’s pretty darn good with a head change. Eheads are a good starter head but KRE HP is a better bang for your buck!
Blower cheaper, HAH........build one first then see how cheap it is! It don’t cost much to run 20’s.....seriously, go make some HP!
GTO George
Old 03-22-2018, 05:58 PM
Dragncar Dragncar is offline
GTO George
KRE High Ports are the better head (have both) Still, one has yet to beat Mike L.
Shows how underrated the E head is and just how good Mike, Marcella and S Brown were together.
If Langer says he is going boost because even "he" can not afford it anymore, I will take him at his word. 5K for a weekend. I spend 200$. Heard he has several sets of 500$+ pac springs in his pit. Checks them every run. Expensive game.
Old 03-22-2018, 06:15 PM
GTOGEORGE's Avatar
Langer is running heads up I’m sure they all are dishing out that much! If you want to play you got to pay! $200 for you that’s probably counting a $125 entry fee! LOL! I go through 4 gal of alky per run, that’s not counting warming it up that’s another 4 gal at up to $4.50!a gal.
GTO George
Old 03-22-2018, 07:16 PM
wreckmastr's Avatar
$4.50 LOL I would be happy to pay even $14.50 a gallon!
Q-16 $17.60 a gallon.
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
Old 03-22-2018, 07:18 PM
GTOGEORGE's Avatar
Yes but I go through 4 gal a pass.
GTO George
Old 03-22-2018, 07:30 PM
wreckmastr's Avatar
GTO George
1.8 gallons here so .......
Originally Posted by slowbird View Post
$17.60 is worth it for Q16, it has such a pleasant smell, who wouldn't pay to smell it!
I hate it
6.98 @ 199mph
4.53 @ 164mph
Old 03-22-2018, 07:32 PM
GTOGEORGE's Avatar
Ok........you win!
GTO George
Old 03-22-2018, 08:49 PM
slowbird's Avatar
slowbird slowbird is offline
I hate it
You can always tell who is pouring Q16 into their tank based on if they are holding their breath and turning their heads away. Lol.
We left the gas cap off the fuel cell for one pass on accident, about half track the fumes got so bad i couldnt breath, let out and rolled down the window which made it WAY worse. It sloshed about .5-1gal out of cell and took about 2hrs to air out before i could sit in the car again. But the stuff makes good power, lol
Old 03-22-2018, 07:26 PM
slowbird's Avatar
twooldgoats's Avatar
twooldgoats twooldgoats is offline
I pay less for methanol, then add cinnamon flavor. Now that's a good smell!
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 03-23-2018, 06:12 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Langer, don't stop short !
Old 03-23-2018, 01:19 PM
John Langer's Avatar
John Langer John Langer is offline
Let's be clear. I never said I could not afford na racing anymore. There is more bang for the buck and more venues to race at with a power adder.
Old 03-23-2018, 03:02 PM
Mike Davis's Avatar
Fact---
Langer's budget for Beer at the races exceeds most peoples race program budget.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 03-23-2018, 03:46 PM
Originally Posted by Mike Davis View Post
Fact---
Got to keep those body systems flushed out.
What Langer does with his money................
is John Langer's business.
Old 03-23-2018, 04:20 PM
Not the best choice of words John. But your info opened my eyes on just how expensive the high end NA game is.
Unaffordable to most. Can not wait to see what you come up with. You set the bar at the top with your NA effort.
Quite certain you can afford whatever engine you want. You have never been one of those check writers who does not know what they are talking about.
Old 03-23-2018, 06:07 PM
wreckmastr's Avatar
In several different threads and posts you have said how it's so much cheaper to build a power adder combo. I find that laughable.
When we're talking about max effort combos here not street stuff power adders cost as much if not more! Max effort combos require quite a few "one off" items you just don't build one with off the shelf chit. If it was so much cheaper and affordable don't you think everyone would be doing it.
Talk about things you have first hand knowledge of not what so and so told you.
6.98 @ 199mph
4.53 @ 164mph
Old 03-23-2018, 06:09 PM
GTOGEORGE's Avatar
DITTO!
GTO George
Old 03-24-2018, 01:24 AM
Care to share how much your top end cost ? How much power does Chief have, how much did his cost. Bet it was 1/4 of what yours did.
Hey man, if you got the money, great, god bless you. How much power do you think you could have made with your best I knew of, 420cfm E heads ? Far better than Justins. You have the biggest centrifugal there is.
Awesome car by the way. What classes do you race it in ?
Old 03-24-2018, 07:25 AM
wreckmastr's Avatar
It was within our budget.
How would I know and why would I care? Apparently you haven't priced a pair of Precision GenII turbos lately.
As always all you seem to care about is flow bench numbers. Boosted applications are much different than N/A when it comes to head flow. The larger the port the harder it is to make boost. Just like most of the big HP boosted motors are all under 600c.i. it takes a lot of air to fill a big cylinder. You can't keep thinking of a boosted motor in the same logic as a N/A motor.(but I'm sure you already knew this all this)
No we do not. We run a F-3 136 @ 71% The biggest is a F-3 143
[QUOTE]
We run in a local heads up series http://www.warriorsraceteam.com/home.html
and some other heads up races here in the Mid Atlantic region.
6.98 @ 199mph
4.53 @ 164mph
Old 03-25-2018, 03:00 AM
What is the valve spring like on a high effort NA engine with a 1.1"-1.2" lift cam ? How often do you have to check them ? Pac springs for my junk to be 450$. How much are those springs ?
That is the kind of thing I was referring to. People now are building turbo stock block/head combos that are running 9s and driving to the track. Do that with a aftermarket block and a decent used set of heads can make 1600+ HP and still drive it. You dont have to spin them to the moon either. 8000+RPM NA engines are cubic dollar destroyers. No fancy pans, dry sump, billet pistons, 1500$ring packs, 8 counterweight cranks either.
Common sense dictates things, nature dictates things.
None of it is inexpensive. Its like you are trying to money shame me or something. It takes 2 guys to fund "your" car.(but you get the brown end of the stick) If you want to tell us all about your "one off" things to make yourself feel like a big shot, knock yourself out.
But I do not think for one second you had to pay 30K+ for a one off top end to make your power. Could have done it with Dons RAV heads and a F3. Chump change comparatively.
Don't big shot me because you got money. You work hard and all and can spend it how you like. Just trying to figure out your deal. Give hard earned money and time to a car you don't own, don't get to take down the track. But he "lets" you be the online guy, brag about it and show pics.
That's a great deal. I find it laughable.
Tell you what, nobody is going to run my timing up right in front of me and burn my engine up.
