Old 03-25-2018, 04:42 PM
er455 er455 is offline
Default My sleeper T/A at car show
https://youtu.be/1XgVA9cHxn4
Old 03-25-2018, 06:39 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is online now
That's real nice !
Old 03-25-2018, 07:41 PM
JLMounce JLMounce is offline
Incredibly awesome!
-Jason
1969 Pontiac Firebird
Old 03-25-2018, 09:13 PM
Are you happy with the FITECH system so far?
Old 03-26-2018, 09:02 AM
Hey Tom yes the FiTech is pretty damm good and easy to setup but there are a lot of parameters in the system that unless you are a tuner which I am not, it can be confusing but with somebody who can understand the terminology of what can be adjusted it would be benifical... my car did not run right with a carb on E85 and now runs great it could be fined tuned better but need to find a tuner to do that because every time I start messing with the pro tuner section of the unit I get myself in trouble ... but I would highly recommend the FiTech system over a carb .
Old 03-26-2018, 09:36 AM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Great to see another turbocharged Pontiac street car, looks awesome!
Old 03-27-2018, 12:53 AM
70 bird's Avatar
70 bird 70 bird is offline
Looks great!! Keep us updated on the fi tech tuning progress.
Old 03-27-2018, 01:09 AM
73 TRANSAM 73 TRANSAM is offline
Whos E85 carb did you ran? Thanks.
Old 03-27-2018, 07:17 AM
JSPONT's Avatar
JSPONT JSPONT is offline
Be careful with turning that boost up. On E85 that fi tech is only good for around 800 h.p. 1200 on pump gas. Watch the a/f close. At 12 psi you should be over 800.
Car looks great by the way!
Old 03-27-2018, 08:47 AM
Thanks Jeff, I know about the 800 hp on e-85 which sucks ..... at the track I can switch to race gas and retune the a/f stays the same all you have to do is put the correct engine size back in the program , now I add 30% to the size for E85 ....
Old 03-27-2018, 02:42 PM
dreamn69 dreamn69 is offline
Do you have any links to your build? Car is awesome!
1972 Formula 455HO
1979 W72 Fire Am
1975 455 4 speed TA
Old 03-27-2018, 04:22 PM
Sorry I did not keep a build update as I was trying to hide most of it from my wife 😂 but I can answer any questions about the build if needed
Old 03-27-2018, 10:42 PM
I'm most interested in how you have your manifolds, wastegate and oil feed/return lines routed.
Did you utilize a water jacketed center section?
-Jason
Old 03-28-2018, 08:46 AM
I have a stock drivers side manifold then a crossover pipe that goes under the car around the oil pan to a handmade custom log manifold , the oil feed line come of the block next to the distributor location, the oil return is a #12 braided Teflon hose that goes to the oil pan in front right under the timing cover were I have a 3/4 “ pipe welded to the pan with a 12 an fitting on it .....the turbo drain is a straight shot to the pan with slight bend this is very important .... hope this helps
Old 03-28-2018, 10:54 AM
Thanks, that's absolutely helpful!
-Jason
Old 03-28-2018, 09:47 PM
Sounds like you have all of the bases covered on your TA, Great Work.
Old 03-29-2018, 08:03 AM
Thanks Tom , hey do you think having a 3.5 “down pipe going into 2 - 2 1/2 “ pipes is a restriction on hp ?? Is a 3” exhaust system in order ?
Old 03-29-2018, 05:04 PM
On my setup, I have a 5" downpipe about 2 feet then neck down to 4". Then I'm going to do a two 3" pipe to the muffler. This is with a PT91.5 G trim single.
Old 03-29-2018, 05:20 PM
NA two 2.5" pipes support 500 hp with NO restrictions. Two 3" around 700 hp before it starts to restrict. You can certainly make power above those levels, but that's the @ power level those pipe sizes support before they start creating restriction.
Starting out at 5 and gradually reducing helps reduce back pressure. The turbine will like lots of expansion at the exit, so don't get shy if you have space for BIGGER!
Old 03-29-2018, 07:30 PM
The larger down pipe right off of the Turbine discharge does two things:
1) ALLOW THE SWIRL FROM THE TURBINE TO CHANGE FROM ROTARY MOTION TO LAMINAR FLOW.
2) REMOVE MORE HEAT FROM THE EXHAUST IMMEDIATELY AFTER IT EXITS THE TURBINE (MORE SURFACE AREA TO COOL THE EXHAUST.
You really only need about 12" of length.
Example: A 12 inch piece of pipe 4 inches in diameter will have 150 cubic inches of volume to convert from Radial Flow to Laminar Flow.
It will also have a large enough surface area to cool the pipe flow so that the exhaust has a denser volume and can pass thru a smaller diameter efficiently. Going massively long on the length really just allows the exhaust to pack up in the volume and disrupt flow.
