Old 05-07-2018, 02:38 PM
63Banshee's Avatar
63Banshee 63Banshee is offline
Default 1970 non-console 4 spd shifter
Complete 1970 non-console 4 spd shifter wanted.
Old 05-09-2018, 01:41 PM
gtobird's Avatar
gtobird gtobird is offline
I have a Hurst shifter in decent condition, but I'm not sure what it came out of.
Do you know the part number on the shifter body and the shifter stalk? I can check to see if it's a match.
Old Joe
Old 05-09-2018, 03:30 PM
For???????????????
Old 05-09-2018, 06:30 PM
unruhjonny's Avatar
they are out there... I'm pretty sure an eBay seller who rebuilds them has a couple listed right now.
1970 Formula 400
Old 05-10-2018, 12:54 AM
63Banshee's Avatar
Originally Posted by Chief of the 60's View Post
For???????????????
70 firebird. Is that a trick question?
Old 05-10-2018, 12:55 AM
63Banshee's Avatar
Old Joe
I'm not a bird guru, so I wouldn't know for sure without some research of my own. I just know the car I'll be working on is a 4spd non-console car. Post pictures here and I'll take them to the tech page.
Old 05-10-2018, 09:11 AM
Old 05-10-2018, 09:28 AM
raggedjim raggedjim is offline
Are the shifters different for a console vs. non-console car?
Old 05-10-2018, 10:29 AM
Some of the non-console cars used a different stick, while others got the same stick as the console cars. Here is a picture of both sticks side-by-side.
Old 05-10-2018, 12:05 PM
Thank you!
Rg
Old 05-11-2018, 12:31 AM
63Banshee's Avatar
Firebird parts wanted forum... 1970 non-console 4spd shifter in the thread title... Not even Carnac the Magnificent can get this one wrong.
Old 05-11-2018, 12:32 AM
63Banshee's Avatar
Shifter ball color have significance between 4 spd cars or was that a 3 spd/4 spd difference?
Old 05-11-2018, 11:22 AM
Both the shifter sticks in the picture had been rechromed, so I stored them wrapped in an old sock with old shifter balls installed in order to protect the threads, so the color of the shifter balls in the picture has no significance as far as application. In 1970 the big black shifter ball was used in both the three and four speed cars, although I'm sure some will disagree with that and say that the leather wrapped shifter knob was used as well. Either way, I do not believe they used a white shifter knob/ball at all, at least not in 1970.
Old 05-11-2018, 04:04 PM
unruhjonny's Avatar
according to the January 2002 High Performance Pontiac article, 1970, and early 1971 Firebirds (generally Formula and Trans Am) which came equipped with a Hurst shifter but without a console were supposed to receive a #7945 shifter arm;
Hurst shifted Firebirds built in that same time frame which were ordered with a console were equipped with a #7244 shifter arm.
As shared on post #9, the #7945 shifter arm has the bend in a greatly different location than the #7244 shifter arm.
The very same article says that from 1972 through to 1978 all Hurst shifted Firebirds received the #7244 shifter arm.
It is worth noting that any Hurst shifted 1979-1981 Firebird would have received a #0800 shifter arm.
1970 Formula 400
Old 05-11-2018, 10:50 PM
63Banshee's Avatar
Excellent info, thanks!
Old 05-13-2018, 11:51 PM
unruhjonny's Avatar
I am, as always, happy to help
