So it'll be 2.5sec faster now?
4.9's............i doubt it! LOL!
GTO George |
He's calling for 1.5 secs faster than 7.4
Probably around 1 second faster just in the car switch then whatever voodoo magic is under that hat now . |
Did no want to take the time and make up a couple of simulation since I really do not know a whole lot about either car. So I just went quick and dirty knowing that would be quicker. Well here you go.
3450# cd .4 frontal area 22 sq ft 60 Foot ET = 1.2022 330 Foot ET = 3.1697 1/8 Mile ET = 4.8083 1/8 Mile MPH = 150.3887 1000 Foot ET = 6.2154 1/4 Mile ET = 7.4063 1/4 Mile MPH = 189.2569 2350# .3 cd frontal area 19 sq ft - improved traction 60 Foot ET = 1.0485 330 Foot ET = 2.7530 1/8 Mile ET = 4.1756 1/8 Mile MPH = 172.7142 1000 Foot ET = 5.4018 1/4 Mile ET = 6.4400 1/4 Mile MPH = 217.1396 I guess we will know in a few week how far over this is. Stan
GTO Geirge |
You do understand the better the 60 foot time on the 7.4 run the less HP it shows / takes for that run. So when I reduce the weight the 6.44 run will be slower because I will be using less HP for that simulation. ![]() Stan
Another gizmo shows -
3450 lbs @ 7.40 = 1683 horses 2350 lbs @ 6.51 = 1683 horses 2350 lbs @ 5.98 = 2172 horses = 489 more horses needed in the stable thats just RawData - no account for better aero , traction/downforce , etc... but still gonna need a lil more boost under the magic hat to break into 5.9's |
Really neat looking new car! Great idea using a proven engine combination in a new chassis.
Best of luck to you, we need all the fast Pontiacs we can get! There just aren't enough of us. Stuart |
So what would one of your simulations be with my car? GTO George |
I had an old sim I had done about 3 years ago. I had to make a few changes to it as some data like the weight based on your signature I had was wrong. 60 Foot ET = 1.1556 330 Foot ET = 3.2795 1/8 Mile ET = 5.0854 1/8 Mile MPH = 136.8021 1000 Foot ET = 6.6549 1/4 Mile ET = 7.9935 1/4 Mile MPH = 169.0700 Stan
One reason I keep posting my simulations is to see how close they come to actual track data.
When I ran these simulations I tried a few different PG ratios and then tries a few 3 speed ratios. From the limited number of tries the best simulation was the one I posted and that used a 1.82 1.37 1.00. Stan
Hopefully the air is better at Norwalk and we're going to put a little more counterweight on the clutch to load it harder in low gear. Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” |
