Old 08-12-2018, 12:06 AM
Schurkey Schurkey is offline
The V-6 was an interesting design. GMC also built a 702 cid V-12 version. V-12 block, cam, crankshaft. and distributor. Add two pair of V-6 heads, two pair of V-6 exhaust manifolds, and two V-6 intake manifolds.
There were Diesel versions of the V-6, along with a V-8 variant.
The 305 was the little guy. Other gasoline V-6s were 351, 401, and 478 cid. As you might expect, this thing was BIG and HEAVY.
"I" would be looking for a 401 or 478 to stuff in that pickup. Talk about novel!
http://www.6066gmcguy.com/index.php
Old 08-12-2018, 12:55 AM
GTOLiam's Avatar
GTOLiam GTOLiam is offline
Picture of my GMC V-6.... not sure what it weighs but it broke a cart I put it on to roll it into storage
"Hammer to fit, paint to match"
Old 08-12-2018, 01:06 AM
Some years back I put a 455 in my 1961 Chevy PU using all factory parts. I believe the Chevy truck frames are similar through 1972. I used the brackets that the frame half of the motor mounts from a late 1970's Chevy truck bolt to. They bolt to the top of the frame rail and to the top of the front cross member. I also used the Chevy's large rubber frame half of the motor mount. I used the Pontiac metal half of the engine mount bolted to the Chevy bottom frame mount. I assembled everything then lowered the engine into the frame. Where the brackets hit the frame rails and cross member I drill holes and bolted it all in. It wasn't necessary to fab anything.
Old 08-12-2018, 11:28 AM
The Champ's Avatar
Did your Dad sell GMC's in Canada ?
Thats a GM of Canada order form
We were in MN - but less than 100 miles from Canada ...
I missed that that was a Canadian form.
Old 08-13-2018, 09:09 AM
77 TRASHCAN's Avatar
Good to hear!!!
Big torque Pontiac engine in a pickup...a good thing!!!
Shut it off
Shut it off
Old 08-13-2018, 08:46 PM
Ducks Goat's Avatar
Ducks Goat Ducks Goat is offline
The '70 GMC my sister has was originally 307 powered and dad's current '68 GMC project was a 305 V6, he used the big car mounts on both engines and made his own frame mounts in order to position the engines where he wanted them, The '70 has RA manifolds and the '68 will have plain logs. Here are the pics I was referring to in the assembly manual. You can clearly tell its a Pontiac engine by the valve covers, exhaust area, and the bolt going fro the timing cover to the intake.
ID:	490375   Click image for larger version
1999 WS6 Formula, 1 of 175
1967 GTO Linden Green 4 spd, A/C, survivor
1967 Lemans convt
1967 Firebird 400 bench seat, deluxe interior, auto
1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, [email protected] (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne.
1961 Catalina 2 door htp
1960 Ventura 4 door htp wife's car
1960 B'ville 2 door htp
1960 Catalina Wagon wife's car too
Old 08-14-2018, 07:29 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
Also the picture shows the starter on the drivers side, Chevy is on the passenger side.
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
