Old 08-22-2018, 06:49 AM
grandville455's Avatar
Default My New Pump Gas 505!
Dynoed the new motor yesterday, made 8 pulls, last one we tried 26 degrees, 7th was the best for the day@28 degrees timing and 112 BLP jets, we stopped there as it was heat soaked, hopefully finish it up later today and pull it higher to see what it looks like up top, I'm totally stoked with the new build and the early numbers its showing! 91 Octane and same KRE D Ports from last motor
Darby
M/T 275/60 ET SS Drag Radial
Old 08-22-2018, 07:21 AM
Looks great!
Congrats!
Old 08-22-2018, 07:22 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Very nice
[email protected]. 3460#s
Old 08-22-2018, 07:40 AM
Gary H's Avatar
Gary H Gary H is offline
Very impressive! I see that it liked 29 degrees timing best, and I've read and heard others say the same thing. For some reason the engines I've built with those heads always showed they liked around 32 degrees best on the dyno. Don't really know why. Congratulations though, great numbers!
Old 08-22-2018, 07:44 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Good job Darby! Nice build.
Go fast, see Elvis!
Old 08-22-2018, 07:45 AM
Scott65's Avatar
Scott65 Scott65 is offline
Congrats, good job
'65 Tempest 467 3650# [email protected]
Old 08-22-2018, 07:46 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Awesome !
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 08-22-2018, 08:08 AM
Hooter's Avatar
Hooter Hooter is offline
Something I've learned from a few dyno sessions - be sure to use you own timing light at the dyno session and not rely on the dyno operators light. I had an experience where there was a slight difference between the 2(his was a dial back and mine a old conventional). Great numbers either way.
67 Bonneville ragtop
Old 08-22-2018, 08:11 AM
Thanks Brad! I agree, I brought mine to use, and once were done i'll verify what mine says compared to his, and well also be using my digital7 ign box and coil, that way its how it is when in my car, yesterday was his 6al analog box and tower coil, and we only did that cause we knew it worked to get the tune in order for the most part.
Darby
Old 08-22-2018, 09:30 AM
Nice
Did you just up displacement and maybe cam change?
Will be interesting to see how the car picks up.
Old 08-22-2018, 09:31 AM
AG's Avatar
AG AG is offline
Great numbers. What is the cam and what are BLP jets? What was the BSFC numbers?
Old 08-22-2018, 09:35 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Awesome congrats! What cfm on the heads?
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 08-22-2018, 09:47 AM
Good numbers! Now get that thing in the car for some shake down runs!
Old 08-22-2018, 09:58 AM
Bruce, Cam change also, 55mm LSM Cam, Ls FIRING Order, .904 morel bushed lifters
Darby
Old 08-22-2018, 10:01 AM
55 mm LSM cam, ls firing order, 270/276@112 LSA, Bolaws Performance carbs .112 orifice size, The one earlier pulls showed a avg of .415!! She's efficient as hell!
Darby
Old 08-22-2018, 10:03 AM
Heads on a tight flow bench and a 4.18 bore were 325@700, Probably about 335-340 on this bigger bore.
Darby
Old 08-22-2018, 10:04 AM
Thanks Skip! That's the next plan after we find its final numbers, we haven't even pulled the covers and relashed the valves yet
Darby
Old 08-22-2018, 10:11 AM
Scott Stoneburg's Avatar
Great numbers bro.
Old 08-22-2018, 10:44 AM
Nice results, Darby!
Dr. Thomas Sowell
Old 08-22-2018, 10:52 AM
Sirrotica's Avatar
Darby, so how fast will it push the Grandville, instead of the Firebird?...……….LOL
BTW nice numbers!!!
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
