Old 09-28-2018, 02:06 AM
Default '68 vs '69 sport wheel
Are the horn buttons interchangeable?
I know the wheels are slightly different but I'd use the '69 wheel I have if the '68 horn button will interchange. Otherwise, I may sell it.
Old 09-29-2018, 01:48 AM
Here is what I'm working with... I 'restored' the finish. It's not exactly like the original PMD finish but it does look like wood and not plastic. I was able to simulate some grain and the joints. If I'd known how well the joints were going to show, I would have been neater with them and also placed them in the proper place. That was a boo-boo.
Before;
After;
ID:	493881   Click image for larger version
ID:	493882   Click image for larger version
ID:	493883   Click image for larger version
Old 09-29-2018, 01:49 AM
And here's what I'm wanting to know...Could someone compare this horn button with a '67 OR '68 button?
Old 09-29-2018, 12:04 PM
Verdoro 68's Avatar
The ‘68 center is 3 different pieces - the collar which screws to the wheel, the base which is held on by the steering wheel nut, and the button which clips to the base. It looks like you have a collar on yours, but the ‘68 collar is unique due to the shape of the spokes toward the center. You might be able to use the ‘69 collar with the ‘68 base and button. I’ll take/find some pics for you for reference.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 09-29-2018, 05:33 PM
Verdoro 68's Avatar
Hope these help!
ID:	493922   Click image for larger version
ID:	493923   Click image for larger version
ID:	493924   Click image for larger version
ID:	493925   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 09-29-2018, 06:54 PM
Verdoro 68's Avatar
Not exact, but here are a few measurements.
ID:	493941   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 09-29-2018, 07:05 PM
Wow, I appreciate you going to all that trouble and yes it does help. That's exactly what I needed.
I still don't know if it will fit but I think I'll be able to figure it out, yea or nay, with those pics.
Thanks!
Couple of questions for you...Are those notches at the wide part of each spoke needed? Also, how wide are the spokes at their widest point.
Old 09-29-2018, 08:03 PM
Verdoro 68's Avatar
Happy to help. As far as I can tell, the notches don't have any functional purpose. At the widest, the spokes are 1-5/16.
I just realized that the collar on my wheel is clocked wrong. The tab that's at 12:00 should be at 4:00. There's a corresponding tab on the back side of the base that I never noticed. However, I can't find my steering wheel puller and the horn seems to work just fine so I guess it's going to stay that way for now.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 09-30-2018, 12:59 PM
Thanks Ken. Same as the '69. I actually think it might work based on what I'm seeing. I'm not sure about other possible differences (for the purist) but from your pics, I think it will work.
As for the collar, as long as the emblem is straight up and down with the wheel centered it should be a non issue. Thanks again!
Old 09-30-2018, 06:35 PM
dataway's Avatar
dataway dataway is offline
I bet the notches are a safety feature ... so the spokes and outer wheel collapse easier in an accident.
Old 09-30-2018, 06:43 PM
Well, that sounds good dataway but why would they get rid of them the following year?
Old 09-30-2018, 08:30 PM
Scott Thelander's Avatar
Default collars
68 on the top it uses a metal collar
69's have plastic collars
Scott
Old 09-30-2018, 09:15 PM
Verdoro 68's Avatar
The only thing I can think of is maybe the redesigned steering column in ‘69 was able to absorb more of the crash impact?
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 09-30-2018, 09:49 PM
Scott, since you have an example of each, is there a difference in the wheel itself, like the depth for instance?
Old 10-02-2018, 08:52 AM
gtoguys gtoguys is offline
I had a 69 wheel on my 68 GTO for years. I used a 68 reproduction kit from Ames on the 69 wheel with no problems.
Old 10-02-2018, 12:26 PM
GTO68FXSTC98's Avatar
GTO68FXSTC98 GTO68FXSTC98 is offline
The 68 wheel is deeper, but I don't know the dimensional difference.
Old 10-03-2018, 02:11 AM
I knew that I had read somewhere over the years that the '68 wheel differed in depth from SOME other year but couldn't remember.
gtoguys, thanks. I think I'm going to use it, at least for a while.
Old 10-03-2018, 03:27 PM
dataway's Avatar
Didn't they start using "collapsible" steering columns around 69? Maybe that's why they did away with the notches.
Old 10-03-2018, 05:45 PM
Verdoro 68's Avatar
According to the Ames catalog, the '69-'70 is 3 1/4" deep and '68 is 4 1/8" deep.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 10-04-2018, 01:10 AM
When I look at Scott's photo, I can actually see the difference. Wonder why the change? I think I'd actually like it more shallow as the Deluxe wheel is close enough to my chest as is.
