Old 02-08-2019, 02:51 PM
Cardo's Avatar
Cardo Cardo is offline
Default Which Delco Coil do i need?
Looking to use an old stock replacement Delco coil for my Lemans. 389 AFB with points. Do i need the Delco 511 or 512 or either? i Can't seem to find out what the actual difference is.
The Following User Says Thank You to Cardo For This Useful Post:
Old 02-08-2019, 03:13 PM
Good question. I have had both. Back in the day, as long as it was not T.I., we grabbed whatever came out of the box. It always worked.
Old 02-08-2019, 04:04 PM
Kenth's Avatar
Kenth Kenth is offline
ACDelco recommends U505 for 1955-74 Pontiac´s.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-08-2019, 04:15 PM
Cardo's Avatar
Looking old stock here. Don't want to use currently made crap coil. I have found sources that state both D 511 and D 512. Can't find what the difference actually is.
Old 02-08-2019, 05:24 PM
bill ryder's Avatar
bill ryder bill ryder is offline
The correct original coil for a 65 is 1115214. Is that what you were asking??
"Bill"!
Old 02-08-2019, 05:31 PM
geeteeohguy's Avatar
Bolt on either one and run it. It will be just fine.
Jeff
Old 02-08-2019, 06:13 PM
Cardo's Avatar
I'm thinking geeteeohguy is right. I'm asking which REPLACEMENT Delco Remy Coil is correct for my application. My 2 choices are the D 511 which is part number 1115202 or D 512 which is part number 1115238. I was just wanting to know which one was intended to replace the 1115214 that Bill referred to. I have found listings referring to both, but don't know what the difference is. In fact i don't understand why Delco has soooo many different blasted part numbers for a 12v external ballast coil!
Old 02-08-2019, 06:49 PM
unruhjonny's Avatar
*speculation warning*
probably minute differences in manufacture, and as stock was depleted of one type, then another one became it's replacement.
1970 Formula 400
Old 02-09-2019, 06:04 AM
Kenth's Avatar
The 1964-67 replacement coil was #1115134. (1965 original #1115241, 1966 original #1115037).
1968-74 replacement coil #1115238 was used (1970 original #1115410).
Later D512 replaces both.
Primary resistance 1.7 - 2.0 ohms @ 75°F
Ignition resistor wire 1.32 ohms @ 80°F.
D511 is replacement for 6-cyl engines (1965 original #1115184, 1970 original #1115414).
Primary resistance 1.4 - 1.7 ohms @ 75°F.
Ignition resistor wire 1.80 ohms @ 80°F.
Hope this helps some.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 02-09-2019, 07:32 AM
Cardo's Avatar
Thank you Kenth! That is exactly what i was looking for. Last night i did find the specs on the coils, but couldn't find the application for certain. I'll be picking up a 512 in the near future.
Old 02-09-2019, 10:08 AM
8LUG 8LUG is offline
1115187 was the production line coil in 64, 1115214 in 1965
Old 02-09-2019, 11:27 AM
unruhjonny's Avatar
that's some great info!!
1970 Formula 400
Old 02-09-2019, 11:29 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
1966 - 037
The Sun chart for 1965.
Note mistake, Engine code WS and YS should be switched.
Chris.
ID:	505096   Click image for larger version
Old 02-09-2019, 04:34 PM
Kenth's Avatar
Originally Posted by 60sstuff View Post
1965 - 214
1966 - 037
Chris.
I stand corrected, should be 214 for 1965, not 241 as i wrote. Thanks Chris!
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
