Old 04-12-2019, 09:05 AM
TAQuest TAQuest is offline
Default Pontiac Timing Cover Without Indicator
I have one of those timing covers that didn't have the timing marks on it. Previous owner bought it NOS from a warehouse.
Does anyone know a source for the bolt on timing indicator for this Pontiac timing cover?
Old 04-12-2019, 09:17 AM
400 Lemans's Avatar
https://www.frankspontiacparts.com/e...ngineparts.htm
Old 04-12-2019, 09:26 AM
Originally Posted by 400 Lemans View Post
Thanks.
Not seeing anything that would work and available on that page.
Old 04-12-2019, 09:27 AM
This is for a Pontiac 400. Not the Olds 403.
Old 04-12-2019, 09:30 AM
rustedgoat rustedgoat is offline
Does the separate timing tab make this a 1976 and up cover on all style bodies (A, F, G...)?
"Honestly the car will only be there for a few weeks, OK maybe a month at the most"
Old 04-12-2019, 09:32 AM
Not sure on that. Deciding whether or not to just make one if it's not available.
I've been searching online and it's not an easy find.
Old 04-12-2019, 09:38 AM
STEELCITYFIREBIRD's Avatar
https://www.ramairrestoration.com/po...indicator.html
Old 04-12-2019, 09:40 AM
Originally Posted by STEELCITYFIREBIRD View Post
That would work. If I can't find the factory one then I'm going to make one.
Thanks.
Old 04-12-2019, 09:46 AM
it just might be a part people really don't list to sell but, these guys and others are always parting out cars.
alex s
scott thelander
thepontiacman
warchief400
that ramairrestorations one does look nice
Old 04-12-2019, 09:54 AM
alex s
scott thelander
thepontiacman
warchief400
Thanks. It's a rare part these days.
The ram air restorations one does look nice. I'm thinking about making a flat one with some marks on it.
Old 04-12-2019, 09:56 AM
I believe most are integral to the cover, don’t know about pre 68 stuff though.
Old 04-12-2019, 10:01 AM
77 TRASHCAN's Avatar
The cover in question is likely for the 400's with the "hub" only balancer or a 265/301. Both these engines had their own unique bolt on timing tabs...
Shut it off
Shut it off
Yup. Almost all are. This is one that was part of a 'last run' of Pontiac parts GM made at the end of the production of the 400 in 1979 for people who needed replacement parts. I also have a 400 standard block from that run. You could buy these from the warehouses. Maybe still can.
Old 04-12-2019, 10:17 AM
You can look it up on the Wallace Racing timing cover page, part number 526985.
Wallace; http://www.wallaceracing.com/timing-cover-numbers.html
Old 04-12-2019, 10:19 AM
Which brings me my next question;
What is an abbreviated dampener ?
Old 04-12-2019, 10:47 AM
They used them on lowest performance /rpm engines, I believe? ‘77 up, looks like a balancer without the outer ring...small diameter, about the size of std balancer without outer ring beyond the rubber divider.
Make sense?
BTW, I have that setup from a 77 GP 400, don’t believe it wouldn’t work for you without modifying it because of the small diameter of the matching balancer.
Old 04-12-2019, 10:52 AM
My first assumption would be the previously mentioned "Hub" damper which was about 1/4th the size of a normal Pontiac Harmonic Damper.
Make sense?
Makes sense. So that means an original pointer wouldn't work with a regular diameter balancer. No sense in looking for an original pointer then. I'm thinking I'm going to get an older style cover.
Thanks.
Old 04-12-2019, 10:59 AM
http://www.78ta.com/HTAF/index.php?topic=11816.0
Too bad pics are gone
Old 04-12-2019, 11:06 AM
This one works with full size balancers. Seller is the Pontiac Dude.
https://www.ebay.com/itm/Pontiac-Tim...4AAOSwzrxUvrwA
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
