#601
Old 06-05-2019, 07:35 PM
Va68goat's Avatar
Va68goat Va68goat is offline
Default Update
Well, I got word from Paul that the dyno was a success! No mention of a knocking noise!!! It dyno'd at 540hp and 559 ft lbs. I'll post the dyno sheet when I get it! Paul is just addressing a small valley pan leak and once that is addressed, it should be on it's way home!. I can't wait to get this motor and finally enjoy it. It's been one helluva journey but I think I'm at the home stretch!
  #602
Old 06-05-2019, 08:04 PM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
great #'s!!!!
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
  #603
Old 06-05-2019, 08:06 PM
scott70's Avatar
scott70 scott70 is offline
Nice !!!! Youve got to love success stories.
  #604
Old 06-05-2019, 08:45 PM
mgarblik mgarblik is offline
This is great news. So many of these stories have a lousy outcome. Not with anything from Paul, just the hobby in general. You chose your builder wisely. Enjoy your car with traditional Pontiac power! That's plenty of HP to do it too!.
  #605
Old 06-05-2019, 10:11 PM
indymanjoe's Avatar
Gonna need some sticky mickeys to enjoy those numbers!
I am the Thread Killer!
  #606
Old 06-06-2019, 12:36 AM
64speed's Avatar
64speed 64speed is offline
Glad everything worked out. I wanted Paul to build my motor but was just unable to overcome the logistics of an AZ/SC engine ship. I have found a great local builder that seems to have a fine attention to detail so hopefully I can throw up some numbers like you got. In a perfect world we could all get together and show off our cars and engines and do some real racing as well as bench racing.
  #607
Old 06-06-2019, 01:36 AM
gtofreek's Avatar
gtofreek gtofreek is offline
The engine made 559/540 without a tapered spacer under the carb. We re-dynoed it with a tapered spacer and it ended up making 570.5 ft. lbs. @ 4400, and 539 HP at 5700 RPM. From 4700-6300 RPM it made over 500 HP. From 4000-5500 RPM it made over 500 Ft. Lbs of torque. And it made over 560 Ft. Lbs from 3800-4900 RPM. Over all, the average HP is up 10 from the previous best dyno run from the past. This was with a Carb Jeff custom built for this engine that had previously never been run or tested on anything. I'll try to scan the dyno sheets later and post them.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
  #608
Old 06-06-2019, 02:37 AM
64speed's Avatar
Outstanding. Paul I can have my engine dynoed at break in but it won’t be using my sniper fuel injection or timing control. It will just be using the “house holley” and an HEI I bought just for break in. Is it worth doing or should I wait and chassis Dyno it?
  #609
Old 06-06-2019, 11:15 AM
darbikrash darbikrash is offline
If at all possible you should use the as-installed EFI and spark control you intend for the car on the engine dyno. The degree of EFI tuning you can get done on an engine dyno is well beyond what you can do on a chassis dyno due to cooling limitations . The engine dyno has no such limitations. I just did my throttle body EFI 467 on the engine dyno, and the amount of tuning we accomplished was priceless. Even for the "self tune" EFI systems.
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
  #610
Old 06-06-2019, 12:39 PM
JLMounce JLMounce is offline
I second this if such a system is being used. I'm not an advocate of the "self learning" nomenclature that these systems are touting. They can only learn to provide fueling and spark based on what you tell it to do.
Having the engine run and tuned on an engine dyno will be a lot easier to figure out what the engine likes and thus get the system where it needs to be instead of guessing, road testing, changing, road testing until you've got it where it wants to be.
-Jason
1969 Pontiac Firebird
  #611
Old 06-06-2019, 12:45 PM
promptcritical's Avatar
promptcritical promptcritical is offline
Wouldn't a chassis dyno be best? It has the real-life conditions of the installation. I don't really know anything about it though.
  #612
Old 06-06-2019, 01:55 PM
This would work the same, however heat is the issue. If your car's cooling system is up to repeated WOT pulls and light throttle work without airflow from a vehicle moving through the air, it's certainly doable.
As testimony by all the cooling threads there are around these parts, for many people that's not realistic.
-Jason
  #613
Old 06-06-2019, 04:07 PM
STEELCITYFIREBIRD's Avatar
Old 06-06-2019, 11:33 PM
64speed's Avatar
My motor won’t be going in my car for some time so hopefully I can come up with the money between now and then and find a Dyno that can deal with the fuel injection
  #615
Old 06-07-2019, 08:23 AM
Originally Posted by STEELCITYFIREBIRD View Post
  #616
Old 06-07-2019, 10:27 AM
tom s tom s is offline
Im going to break my new engine in on the dyno with carb and known dist.After I get it in the car I will put the EFI on and dial it in.Tom
  #617
Old 06-07-2019, 10:46 PM
Va68goat's Avatar
The valley pan leak is fixed! Apparently the gasket slipped out of place when the valley pan was being installed! Paul says the oil filter was free of debris and looked good. Hopefully the motor will be on it's way home next week! Standby for burnout video(s)!
  #618
Old 06-08-2019, 07:15 AM
gtospieg gtospieg is offline
Eagerly waiting.....congrats
  #619
Old 06-08-2019, 07:46 AM
gata79 gata79 is offline
Who’d you get to build your engine 64speed? Lynch’s machine shop in Greenville builds a lot of Pontiacs.
  #620
Old 06-08-2019, 08:52 AM
I think that part is more concerning. The amount of people that can't keep their engines cool tells me they have other issues and probably won't survive much street driving anyway without causing worry.
When it comes to drivability tuning with loads and real world conditions there is nothing better than a chassis dyno. I've used them several times with no issues of any of the cars running hot. They are used all the time for consistent loads and part throttle tuning. Extremely popular with the computer and fuel injection crowd. Most of them I've been on have excellent air flow with large fans and can pretty much nail down an excellent tune in a matter of hours that would take days of driving on the street.
Closed Thread
