They call for .0045"-.0055" clearance. I originally set them up at .0045", It's been lightly honed now twice so it is now around .0047"-.0048" I can guarantee it's not piston slap. It would need .006"-.007" before you would really start to hear anything loud. Piston skirts still measured really good this last go round.
Scott Stoneburg,
Thats a good suggestion and thats on the list to do. 68 461 Bird, I've thought about that and that is an option but there is not a chance in hell that I'm going walk away from the money I have sent Paul. I've been speaking with Jeff Koerner, so thats a good sign. I have been reaching out to Paul by text but he hasn't returned one. I even sent one last night explaining that we need to work this out away from the forum and that I don't think he's a bad guy. No response from him..So, when Paul chimes in and diverts the attention to everything other than himself...I won't let that happen. Fuel??? Really? It's possible that Paul made a mistake and than missed it again when he tore the motor down and I'm fine with that...lets work this out and figure the problem out. Blame it on fuel??... come on! Sun Tuned, Second opinion is an option but with the money I have spent to build the motor, diagnosing the motor and then recently spent to fix the motor yet the same problem exists, there is not a chance I'm walking away from that. I'm a pretty patient guy.. I'm focused on getting this motor fixed with or without Paul being involved but you would think he would want to be part of the solution. 64speed, Thank you for the information. If it gets down to that, I will reach out. As I said earlier, at this point I'm not willing to walk away from the money that I have spent. I've been communicating with Jeff Koerner and he is actually trying to find someone that can come to my house and check the motor out. I'm appreciative of that and we'll see how that goes. Paul...I'm sure you're reading this so if you're willing to fly to Virginia and take a look..my offer still stands that you can stay at my house. I won't pay for the ticket but you're welcome to stay here. |
It's not difficult to run a line from a gas can to the fuel pump, and it would eliminate any question of the quality of fuel. You HAVE to eliminate ANY possible cause, it's trial and error, so you have to do ALL the steps to have countable results.
Think about it, you put the new tank in when this escapade first began, almost 2 years ago. THAT gas is still in there, and it has sat for that almost 2 years. Adding gas to bad gas makes all the gas in the tank bad. Did you drain the existing gas out of the tank before you added 'new' gas? Do I think it's the gas? Not really, but I admit it is a possible cause that hasn't been addressed yet. If any one of the potential causes that were corrected did not fix the issue doesn't mean that there wasn't any issue with the corrections, like the initial timing and/or the rockers. And don't dismiss that the knock could be caused by a combo if issues. It all needs to be right. The plugs looked a little hot to me, and maybe a little rich. Maybe post a pic or two of those. .
My last post wasn't intended to mean bad fuel.
Was thinking to much fuel in 2 or more cylinders at idle. Have you checked carb for debris? Happened here years ago with a brand new 850 Demon carb. Rear float suck open upon start up. Was surprised how much metal debris was in both bowls and rear channels from factory!
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
On a positive note, there's a lot of great advice on this thread. I am hoping for the best for you! |
Making things right is better for both parties involved actually. |
Sorry you have a hard time understanding. I was only giving advice to the OP and he is the only party I cared about. It appears others agree if these other diagnostics don't work out, its time to dig into it.
Without a doubt the most depressing thread on here. I keep hoping you are going to say you solved this mystery and are out shredding tires. The down time I had on my engine swap which was only a few wks about killed me. Gotta have that Pontiac fix
Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR 236/242D .572/.594L, RA manifolds, 11.53@114, 1.55/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, Howard HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
Yes if you let him build it with his approved parts or agrees with the quality of the parts you provide which was SCAT in my case then if he puts it on the dyno and it blows up he will replace it. If you installed it in your car and it knocked right after he ran it in, he would fix it. If you blow it up racing, well you are on your own
| Closed Thread |
