Great way to rust out your trunk floor trapping moisture. Trunk mats are a bad idea imho.
Don |
| The Following User Says Thank You to dhutton For This Useful Post: | ||
Sorry, but I respectfully disagree. If you have water getting into your trunk, you have bigger problems than having a rubber trunk mat.
Don |
Next time at a car show, lift up someones mat. More times than not, you will see some minor rust starting. |
| The Following User Says Thank You to dhcarguy For This Useful Post: | ||
That was more of an issue back East and pretty commonly seen when I lived in Ohio.
Out here in Arizona not so much of a problem when you have dew points in the single digits and 15% humidity. The mats themselves disintegrate from decades of use while the trunk floor remains pristine. |
| The Following 2 Users Say Thank You to Formulajones For This Useful Post: | ||
There is a "technical" thing called capillary condensation that can bite you when two surfaces are in contact, but like Formulajones, if the RH is 10 or 15%, even that scenario is unlikely. Mike |
You really need to listen to Don. He's right about rubber mats causing rust on the trunk floor. The rubber doesn't breathe. I've seen it first hand. Causes tiny rust pin holes. Whole trunk floor had to be replaced. |
I do not doubt that he is correct, but I like the rubber over the vinyl and can keep the trunk floor in rust free condition with the proper coatings. Where I live in Texas is a dry enough climate that we do not have the rust and humidity problems they have in Houston and the Eastern part of the USA.
| The Following User Says Thank You to Red Box Rebel For This Useful Post: | ||
This happened to me. Moisture got in my tail lights, and started rusting my trunk floor. I caught it in time, and cleaned it up, and re sprayed with spatter paint. I no longer use the mat. I put a blanket on the trunk floor now for my chairs and cleaning tote that I can easily remove or it will absorb moisture and I can simply hang it out to dry and let the trunk air out.
"BIG DADDY" VIDEO http://www.youtube.com/watch?v=QnFIVLuwO9A ~MaryAnn~ AKA "Stickybuns" 1969 Firebird 400 Convertible 1978 Bandit T/A Tribute 1977 RED TA I'm the FiredUp PY bad girl
this happened to my 67
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
