Industry Stuff new repro's, updates, other info.
Old 12-02-2020, 12:12 PM
Originally Posted by Red Box Rebel View Post
When I bought my first GTO in 1974 it was a '68 GTO and it came with a real rubber trunk mat with a black & White hounds tooth pattern.
I am wondering why I cannot find a new rubber trunk mat. With all the GTOs and other Pontiac family A-Bodies and F-Bodies out there, you would think SOMEONE would reproduce the RUBBER trunk mat.
So, everyone needs to call the major parts houses that sell A-Body parts and ask them to find a supplier for real rubber hounds tooth trunk mats.
Rubber is just nicer than vinyl. If someone still makes them, please let me know.
Thank you
They make them for first gen Camaros, can't imagine why a supplier wouldn't have one for other cars if they were so factory equipped.
Our 69Z with deluxe interior comes factory with a pretty thick rubber trunk mat with a houndstooth design on it. I had to buy a new one, they are just over $100. Not a cheap trunk mat but very nice quality.
https://youtu.be/XqEydRRRwqE
Old 06-18-2024, 09:10 AM
Formula403 Formula403 is offline
They were an available accessory option for basically every model of every year.
Old 06-18-2024, 03:34 PM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Originally Posted by dhutton View Post
I was referring to condensation. Constant cycles of heating and cooling will cause moisture to accumulate under the mat. It has nothing to do with leaks....
Don
Absolutely agree. Condensation is a problem, especially if you have an air condition garage . The cool air in the garage will speed up the issue when pulling your hot (body) car in.
Next time at a car show, lift up someones mat. More times than not, you will see some minor rust starting.
The Following User Says Thank You to dhcarguy For This Useful Post:
Old 06-18-2024, 07:21 PM
That was more of an issue back East and pretty commonly seen when I lived in Ohio.
Out here in Arizona not so much of a problem when you have dew points in the single digits and 15% humidity. The mats themselves disintegrate from decades
of use while the trunk floor remains pristine.
Old 06-19-2024, 10:01 AM
The over the Pontiac Parts counter Accesssory style I'm acquainted with from the late '60's were of a thick light gray flexible material. I've had a few NOS from dealer buyouts & have a lightly used one.
Like the much thinner assembly line installed rubber mats, I don't like them. Just pulled in too many projects & parts cars from TX, OK, even from out in NM, where the thin rubber style mats were stuck to the trunk floor. Once the thin mat is carefully pulled up, there's a rust stain on the back of the mat, & at the very least minor rust pitting on the trunk floor. My '72 T/A had a thin trunk mat mat as part of DLX trim interior option. Unless I find a perfect used '72 mat & then go to the trouble of installing & removing it, I doubt the '72's trunk floor ever gets a mat again. Even after refinishing with epoxy primer & modern paint, I'm paranoid about condensation & rust.
Old 06-28-2024, 01:18 PM
Cammer-6 Cammer-6 is offline
Great way to rust out your trunk floor trapping moisture. Trunk mats are a bad idea imho.
Don
this happened to my 67
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 06-28-2024, 03:34 PM
Shiny Shiny is offline
Out here in Arizona not so much of a problem when you have dew points in the single digits and 15% humidity. The mats themselves disintegrate from decades of use while the trunk floor remains pristine.
Same opinion. My rule of thumb when I got paid to think was if average RH is below 50%, risk for corrosion was negligible. Sure, if water sits, it will cause corrosion, but that's a different discussion. Condensation in the desert southwest can happen, but any condensate won't last long before it evaporates, even under a mat.
There is a "technical" thing called capillary condensation that can bite you when two surfaces are in contact, but like Formulajones, if the RH is 10 or 15%, even that scenario is unlikely.
Mike
