#41
Old 10-21-2019, 06:18 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
Originally Posted by FrankieT/A View Post
The answer is right here in the original post...
455 heads on a 400. Low compression no flow...
Try some 12 heads or 48...even 62's would be better.
yep!! I'd start over with the motor or lower your expectations.
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
  #42
Old 10-22-2019, 07:43 AM
Well, I was kind of thinking more along the lines of at least first assessing the currently build before throwing a top end on it in search of more power. If it's a generic rebuild, stock rods, etc, then I personally would either leave it and drive it, build another on the side, or go into and build it in a performance manor.
Clay - Yeah, I've seen the same car dyno on 2 or 3 diff dynos, and the numbers were all over the place. That, and trans/converter also make a diff. You get a sloppy converter that slips 10%, on a 400 flywheel hp build, it makes a fairly large diff. You use a performance built TH400 with high line psi etc on a 350ftlbs engine, you're throwing power away due to parasitic losses.
