#41
yep!! I'd start over with the motor or lower your expectations.
************************************* 1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude |
#42
Clay - Yeah, I've seen the same car dyno on 2 or 3 diff dynos, and the numbers were all over the place. That, and trans/converter also make a diff. You get a sloppy converter that slips 10%, on a 400 flywheel hp build, it makes a fairly large diff. You use a performance built TH400 with high line psi etc on a 350ftlbs engine, you're throwing power away due to parasitic losses. .
