Old 12-02-2019, 06:58 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by ponyakr View Post
"...So how many $1500 blocks do you realistically think would be purchased?"
I don't have a clue.
But, from what I've read on this & other Pontiac sites, a good core block, and all the machine work required to do it right, will cost that same $1500, or more.
I'm not a machinist. So, I don't know what machine shop charges are. But I remember reading that Paul Carter does all sorts of stuff to a core block. Seems the deck has to squared with the crank, and possibly the main journals honed, oil passages & plugs done, etc, etc, etc. Just a guess that all this work, plus the cost of a good 400 core block would be more than $1500.
But, I'd like to see estimates from guys here who know for sure what is required & the costs.
Just for comparison, Butler gets nearly $4k for a ready to assemble shortblock kit. They sell the rotating assembly for less than $2k. So, they're charging over $2k for the machined block.
https://butlerperformance.com/i-2445...tegory:1234783
Len Williams charges $3800 for a 400 block stroker shortblock. So, I figure he's charging over $1500 for the core block & all the machine work.
http://lenwilliamsautomachine.com/455_Short_Block.html
So, I figure the guys who will pay these prices, would gladly pay $1500 for a brand new block, if the quality is equal to or better than an 40+ year old re-machined block.
Some of the old blocks won't stand any larger bore size. Some have lots of corrosion damage. Some have had lots of material cut off the deck, during previous rebuilds. Some don't have the correct holes needed for both 2 & 3-bolt motor mounts.
I just think a GOOD quality $1500 Pontiac block would sell & encourage some guys to go with Pontiac, rather than some sort of Chevy power. Will they sell as good as Chevy blocks ? Of course not. Will they sell fast enuff for a guy to turn a quick profit, no.
There have been lots of guys post that good Pontiac blocks do not exist in the area where they live. And, there are lots of old Pontiac guys that have hoarded up all the cheap Pontiac blocks they have run across, for the last 30 years or longer. These are, no doubt, 2 reasons why some guys have decided to go with Chevy power.
So much for conversation....lets all just stand on our soap box and preach about what others should do for us because we want something.
Go fast, see Elvis!
Old 12-02-2019, 07:27 PM
Just to add to the conversation. I wonder if it has to do with already having a block, or easy access to one.
The guys building a pontiac that don't have a pontiac engine probably aren't doing a factory correct restoration. It may just be a fun build, or a pro-touring or drag car.
How many of those guys will simply just go to an LS/LT?
Kind of makes you wonder if there's even a market for such a block, at least at this time. The guys that want to, or need to make big power have a couple options. Everyone else can either use the block/s they have or may have easier access to.
-Jason
1969 Pontiac Firebird
Old 12-02-2019, 10:17 PM
PAUL K's Avatar
I'm not sure on the LS conversion. I've saved a couple from going that route and they've been totally happy with their Pontiac engines. I my area a Pontiac core isn't hard to come by... but neither are LS engines.
I doubt you'll see a "Sportsman" style block and really don't think there is a need for one. You can make more 600 hp naturally aspirated and have the block live forever. You can make 900 with a power adder and have the block live a very long time. Another concern is, this industry isn't headed in a good direction. Most of the performance companies are being bought by investment groups whose only concern is bottom line profits. All they earned from four years in collage is raise prices and cut costs. The problem is most these companies they're destroying were found by folks that formed the business to solve a need and profits fell into place by selling a quality part that performed a purpose... Another reason a junkyard LS engine seems appealing, but you run into the same issues once you start building to to make more power.
Go fast, see Elvis!
