Old 10-03-2020, 06:30 PM
3fastgtos 3fastgtos is offline
Default Blower manifold
I have a BDS manifold and would like something a little taller with room for port work (Edlebrocks) and EFI port nozzles. I’ve seen the modified tunnel rams and just don’t want the blower that high.
Does anyone make an in between?
SD
Old 10-03-2020, 07:55 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
SD
As far as I know, the BDS is the only ready-made Pontiac blower manifold---anything else is custom and I've only seen them done with Gutsram intakes. As far as custom goes, the sky's the limit, I guess. I looked around a lot when I converted to supercharged and that's all I found.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 10-04-2020, 01:30 AM
Brian Baker's Avatar
Hampton at one time had the only Pontiac manifold that would allow an 8-71 to be run and clear the distributor. Give them a shout.
https://www.hamptonblowers.com/superchargers
Old 10-04-2020, 06:00 AM
I have never seen any other off the shelf blower Manifolds then posted here.
That being said for a time I was looking into making a better and taller blower Intake then the modified Offenouser that came with my Dyers blower set up and I found that the best starting point was the Weiand tunnel ram for a 440 Mopar.
It's port size stock is RA4 size and has good room to grow.
Old 10-04-2020, 12:07 PM
You can put allot of fuel through a hat. What rotor design are you going to run?
Old 10-04-2020, 12:50 PM
It’s a 540R Whipple with an EFI bird catcher. The reason for port nozzles is just for room to grow.
Old 10-05-2020, 09:05 AM
mysticmissle's Avatar
There was a fabbed hogan blower intake on racing junk
Old 10-05-2020, 09:43 AM
Thanks, I just messaged him.
Old 10-05-2020, 11:14 AM
Elarson's Avatar
Elarson Elarson is offline
Boss Bird has a custom Hogan blower manifold; designed to fit our billet heads.
Eric
Old 10-08-2020, 09:08 PM
Fast 69's Avatar
Fast 69 Fast 69 is offline
I have a Hogans fabbed blower manifold just like the one on Racing Junk for half that price. PM if interested.
Old 10-09-2020, 05:16 PM
PM sent
Old 10-09-2020, 05:43 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Too short.
https://www.racingjunk.com/Intake-Ma...old-Satin.html
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 10-09-2020, 05:46 PM
hojs69's Avatar
Sorry, meant to include this also above.
Nice but $$.
https://www.racingjunk.com/Intake-Ma...NIFOLD-.html#1
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 10-10-2020, 12:40 AM
The one RBS sells is the standard fare BDS intake. Short is good because anytime you can lessen the distance from the crank AND keep the pulley as close to the block as possible (laterally speaking), the less stress induced on the crank snout.
If distributor/magneto clearance is an issue, Mike Dunn in Texas can make you an offset drive for a Pontiac (had him make me one years ago, to clear a 14-71 on this very intake). My intake is also drilled/tapped for port nozzles.
Originally Posted by hojs69 View Post
Old 10-10-2020, 11:39 AM
Steve Barcak's Avatar
I set up my vintage Thompson blower intake to run port nozzles and was happy with the tuning advantages of doing so. Later, I moved my port nozzles to my heads on the intake ports and that worked even better. So, you can run your port nozzles in your head- top of your intake ports as I have. That may help you.
This is for a nitro methane application. pontiacheaven.org
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
