Many of those dual-roller chains will gain slack as the roller axles wear in. The double rollers give up a bit of accuracy to gain adjustability and strength for pulling big cams against stiff springs.
I always degree a cam when I install it. I start dot-to-dot, and install it with the cam gear dot at the 6 oclock position and crank gear dot at 12" to make it easier to eyeball the dots really are lined up.
Ok thanks. I’ve never degreed a cam before. I’ve been watching some YouTube videos. With regards to a kit, I see that Jegs and Summit sell one for about $90 and the Comp-Cams one is almost $180! Why the huge difference? Can I get by with the less expensive kit?
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone. The frogs take up where they left off. |
