Old 05-10-2021, 12:21 PM
chiphead's Avatar
chiphead chiphead is offline
Many of those dual-roller chains will gain slack as the roller axles wear in. The double rollers give up a bit of accuracy to gain adjustability and strength for pulling big cams against stiff springs.
I always degree a cam when I install it. I start dot-to-dot, and install it with the cam gear dot at the 6 oclock position and crank gear dot at 12" to make it easier to eyeball the dots really are lined up.
