Old 05-27-2021, 08:05 AM
moneypit's Avatar
moneypit moneypit is offline
Originally Posted by PontiacJim1959 View Post
Ok, sounds good.
Do you have the dyno numbers for idle on up? Was curious as to the HP/TQ numbers since the tunnel ram is often looked down on as a streetable piece at these lower RPM's.
Again, most will say the tunnel ram is for mid-to-upper RPM's but from your dyno sheet, this does not seem to be the case. It seems to peak at a perfect RPM for a street engine.
I am going more for the period look with my set-up, using velocity stacks topped with a Hilborn style scoop.
Another thing I see. You have the finned valve covers. Make sure you have breathers. I see the oil fill cap, and assume a breather on the other side? I also have finned valve covers and will be using the Moon add-on breathers ala the old school look. I mocked them up on an engine I have sitting and will mount the breathers permanent when I have the tunnel ram in place on the engine.
I don't have numbers from idle up, but the car drives great. Crisp throttle response and lots of low and mid power. I do have a breather on the passenger side and PCV valve in the valley pan. Your set-up looks sweet! What's it going in?
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
71 GTO base 400 A/T
97 F250 7.3 turbo diesel
Old 05-27-2021, 09:09 PM
PontiacJim1959 PontiacJim1959 is offline
OK, driving impression sounds like what I wanted to hear.
Putting the engine in a 1968 Lemans I've had about 20 years. Was on the road about 8 of those. Doing a frame-off resto-mod ala mid '70's look, TKO-600, Ford 9", tunnel ram, big & littles, one piece fiberglass tilt nose, jacked up, white interior, tilt steering column, Grant steering wheel, Jensen door speakers in my new white door panels, Kraco under dash 8-track, and all the extra gauges outside the windshield. LOL
Got side tracked with a 1948 International Box truck I am rebuilding for my brother. Have not touched the '68 in 4 years, but I have been purchasing a boat load of parts that'll make it quick to put it all back together. The body is back on the frame.
ID:	567404   Click image for larger version
ID:	567405   Click image for larger version
Name:	03  Ready to roll.jpg
ID:	567406   Click image for larger version
Name:	07 Rear sway bar.JPG
